Author Topic: [IC] QCP (Mini 1800)  (Read 42058 times)
Offline Tyson
Re: [IC] QCP (Mini 1800)
« Reply #50 on: Tue, 11 December 2018, 11:10:11 »
Interested to see more of this board! I love the look of CP boards, but the size and weight are insane! I'd be down to get a mini one!
Offline Yakbats
« Reply #51 on: Tue, 11 December 2018, 20:31:36 »
Yes! I've been waiting for this layout. I'm totally in.
Offline Lndefinite
« Reply #52 on: Tue, 11 December 2018, 22:41:51 »
Yes, I want it.
Offline Acereconkeys
  • Happiness = life - expectations
« Reply #53 on: Wed, 12 December 2018, 13:37:15 »
I am interested in this. Yes. Quite interested.
TMO50 | Jane V2 CE Incoming | Realforce 87u 55g | Aergo
Aergo design and build log: https://geekhack.org/index.php?topic=103681.msg2840918#msg2840918
Offline sozo
« Reply #54 on: Wed, 12 December 2018, 14:07:13 »
oooo i like this a lot!
Offline MrKaishi
« Reply #55 on: Fri, 14 December 2018, 00:28:11 »
Delightful, I like.
Offline katotaka
« Reply #56 on: Fri, 14 December 2018, 12:40:32 »
as much as my interest I'm also curious about layout options, for instance, the bottom row
Offline ArdentHandsaw
  • When the wind is southerly
« Reply #57 on: Fri, 14 December 2018, 13:57:47 »
Hello, yes, I want one.
hasu'd FC660C | Tada68 | MF68 | M10-A
Offline davisthegreat
    • 3DKeebs
« Reply #58 on: Tue, 18 December 2018, 12:41:42 »
Im in the bootloader pcb minority, the simplicity makes me happy
Offline speaktobrett
« Reply #59 on: Tue, 18 December 2018, 22:41:42 »
Very interested.. but i would like to see some more info such as materials, layout options if any, programming etc.
Offline factoryofidols
« Reply #60 on: Wed, 19 December 2018, 10:31:06 »
I’m definitely interested in this
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #61 on: Wed, 19 December 2018, 12:48:32 »
Probably either 6061 or 6062 aluminum case, brass weight, brass, aluminum, and possibly polycarbonate plate options, very likely to be somewhat/completely fixed layout, PCB is QMK.
Correction, Quantrik always uses 6063.
« Last Edit: Wed, 19 December 2018, 14:55:55 by zekkin »
Offline Visionaire
« Reply #62 on: Wed, 19 December 2018, 13:07:15 »
Interested
Offline Quantastrophus
« Reply #63 on: Wed, 19 December 2018, 14:58:56 »
Will it be from the same factory as qxp?
Yes
There will be 2 different plates for 2 bottom row options
- 1.5 1.5 7 1.5 1.5
- 1.25 1.25 1.25 6.25 1.5 1.5
Material of the case? Any idea on what colors may be available?
Material: 6063 aluminum
Colors: Black, Silver, Blue Grey, Dark Purple
Need more info pls
Cool
QMK Type-C
Super interested! Hope the pcb is qmk compatible
Yes
Looks solid and I'm interested, but if we removed the number row as well I'd be ULTRA down.
But then I'd have to throw the board in the trash  :cool:
Offline clasicks
  • Formerly KeyboardUser4
« Reply #64 on: Wed, 19 December 2018, 15:10:59 »
Thanks for the clarification - GLWGB - Not my preferred layout but if the fit and finish are similar to your QXP boards you should have some happy campers!
Offline Xerpocalypse
« Reply #65 on: Thu, 20 December 2018, 11:59:12 »
This board looks great, I'd love to buy one.
Offline forevermadrigal
« Reply #66 on: Thu, 20 December 2018, 18:06:19 »
ty senpai
Offline dr_unconscionable
    • [sqeleton]
« Reply #67 on: Sat, 22 December 2018, 02:09:31 »
I love 1800 layouts and small boards, but I think I'm still going to hold out for an eventual R2 of yangdigi's 1800mini -- the numrow is really the superfluous part of the 1800 for me (as a couple of people said upthread), and something about that other layout really speaks to me. This is a good looking board though! Hope the GB goes well!
Offline MikeTheTiger
« Reply #68 on: Sat, 22 December 2018, 07:05:43 »
Wow, that is a nice board!
"all the numbers or none of them cmon man" -Kokaloo
« Reply #69 on: Thu, 27 December 2018, 15:18:18 »
Do you know when this board will be going to groupbuy?
Offline E.E.L. Ambiense
  • Acrylic Heretic
« Reply #70 on: Thu, 27 December 2018, 15:48:08 »
Beautiful deck!  Depending on price and time-frame, I'm totally down for a new gaming deck.
Case modder by trade; mech-deck'r for fun!
Offline ArchDill
« Reply #71 on: Sat, 29 December 2018, 22:40:34 »
This is so pleasing to the eye. I am digging it.
Offline Rykno
« Reply #72 on: Sun, 30 December 2018, 00:41:02 »
Any hope for 6.25u spacebar?  :-*
Offline thornkin
« Reply #73 on: Mon, 31 December 2018, 01:00:54 »
Loving the look.  Would be interested in what the options for the spacebar row would be.  Will there be options for a windows key?
Sent from my Mediatek MTK8173 Chromebook using Tapatalk
Offline JFKroflcopter
« Reply #74 on: Mon, 31 December 2018, 03:23:21 »
- 1.5 1.5 7 1.5 1.5
 :thumb:
Offline katotaka
« Reply #75 on: Mon, 31 December 2018, 08:58:19 »
hmmm how about top (number) row?
I was too excited, not sure if I can get used to that
Offline Sshimosawa
« Reply #76 on: Mon, 31 December 2018, 20:27:41 »
Youre not sure you can get used to the top number row?
Offline katotaka
« Reply #77 on: Tue, 01 January 2019, 03:49:36 »
ESC on `~ is fine as in most 60%
\| and `~ on split BS and BS on \| ? not so much
plus I hate not able to fill with normal keysets and "incorrect" profile heights
Offline mnpq.raven
« Reply #78 on: Tue, 01 January 2019, 06:58:10 »
you know you can program it to how you want right ?
Offline KaosJ
« Reply #79 on: Tue, 01 January 2019, 07:14:46 »
That layout, so hot, you have my interest!
Any pic of the bottom?
Are these leds indicator above the arrows?
Offline katotaka
« Reply #80 on: Wed, 02 January 2019, 22:42:08 »
My concern is physical openings for stab / switch on plate and PCB, it might be compatible with both 2U and split BS but I didn't see it mentioned... Anyway, not deal breaking issue, the want is still strong
Offline dexie
« Reply #81 on: Thu, 03 January 2019, 09:21:42 »
Super interested in it. Can't wait for the GB!
ISO Life
Offline JPVann
« Reply #82 on: Thu, 03 January 2019, 10:50:21 »
Have been looking to get rid of the F row with a design like this.  Yes please.
Offline OtherAndrew
« Reply #83 on: Thu, 03 January 2019, 12:38:56 »
F
Offline Gati
« Reply #84 on: Thu, 03 January 2019, 13:30:32 »
F
Offline duckboi
« Reply #85 on: Thu, 03 January 2019, 14:19:22 »
F
The m0ar empty you feel,  the m0ar space for Keycaps..
Offline RamenTechMech
« Reply #86 on: Thu, 03 January 2019, 14:20:27 »
F
Offline zekkin
« Reply #87 on: Thu, 03 January 2019, 14:40:26 »
goodnight sweet prince
Offline Rykno
« Reply #88 on: Fri, 04 January 2019, 14:49:00 »
Another layout question: can it support split
  • on numpad? I like to have backspace in the corner above - / +
Offline InvidiousIgnoramus
« Reply #89 on: Fri, 18 January 2019, 15:58:53 »
Quant pls
I long for the day when I find a beamspring. (At a not insane price)
Offline dimo
« Reply #90 on: Fri, 18 January 2019, 19:36:04 »
Add this with wob hiragana to the dead pile
Offline forumusername
« Reply #91 on: Fri, 18 January 2019, 20:08:20 »
This died ?
Offline dantambok
« Reply #92 on: Fri, 18 January 2019, 20:23:39 »
RIP QCP
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline GigaFlop
« Reply #93 on: Fri, 18 January 2019, 21:40:49 »
I'm interested, depending on price. I've yet to get my hands on an 1800 layout.
Oh god why did my wallet get so thin
Offline thornkin
« Reply #94 on: Sat, 19 January 2019, 01:08:45 »
Why is QCP RIP?
Sent from my SM-G950U using Tapatalk
Offline travwal
« Reply #95 on: Sat, 19 January 2019, 11:08:24 »
Is this seriously not happening?  :(
Offline chuckdee
« Reply #96 on: Sat, 19 January 2019, 13:12:00 »
Until the OP says so, I wouldn't assume.  Of course, long silences don't help.  But there's sometimes a lull as they look at options.  Same with WoB Hiragana hopefully.
Offline Zytyx
« Reply #97 on: Sat, 19 January 2019, 13:36:47 »
Quantik said on the mk reddit discord they wouldn't be doing it because their manufacturer got leaked and prices would be too high.
« Last Edit: Sat, 19 January 2019, 15:43:13 by Zytyx »
Offline travwal
« Reply #98 on: Sat, 19 January 2019, 13:59:23 »
Quantik said on the mk Reddit they wouldn't be doing it because their manufacturer got leaked and prices would be too high.
Do you by chance have a link to the post? With the other group buys that he has run, I'm surprised it would be drastically different in price
Offline Tyson
« Reply #99 on: Wed, 23 January 2019, 12:07:43 »
You do know that normal keysets come with split bs caps in the right profile. It's common for keysets to have the caps for HHKB layout which uses split bs. This board is using caps that normally come in standard base keysets, there isn't any special keys that would require you to buy different kits for compatibility.
