Author Topic: [IC] BnB87: Gasket Mount TKL  (Read 54612 times)
Offline oldcat
  • 65% is Life
Re: [IC] BnB87
« Reply #50 on: Sat, 02 March 2019, 18:56:59 »
Hey Lbibass,
I am using the white mode to read, and some texts have some issues. (guess its intentional)
« Last Edit: Sat, 02 March 2019, 19:04:36 by oldcat »
Offline Nigolski
Re: [IC] BnB87
« Reply #51 on: Sat, 02 March 2019, 19:04:03 »
dope
Offline Lbibass
Re: [IC] BnB87
« Reply #52 on: Sat, 02 March 2019, 19:10:51 »
Hey Lbibass,
yeah, that's the spoiler probably. That's the old IC. The text up top is the revised IC.
Offline Lbibass
Re: [IC] BnB87
« Reply #53 on: Sat, 02 March 2019, 19:27:06 »
Why the choice of a small brass weight instead of a large one?
Mainly because I prefer the aesthetics of a smaller weight. Plus, I would rather the cost be a little bit lower. And the weight is already at 2.94 pounds, without a PCB, caps, or switches. Or any screws, for that matter. There comes a point where a board is just too heavy, and I would like to avoid that.
Offline mellen
Re: [IC] BnB87
« Reply #54 on: Sun, 03 March 2019, 03:03:00 »
what about no cutouts, id rather see brass than pcb
Offline balduran85
Re: [IC] BnB87
« Reply #55 on: Sun, 03 March 2019, 06:00:36 »
I second this. Unless the pcb design is aesthetically superior to the brass plate, which often is not.
Offline oldcat
  • 65% is Life
Re: [IC] BnB87
« Reply #56 on: Sun, 03 March 2019, 11:17:57 »
It's possible :)
Offline Lbibass
Re: [IC] BnB87
« Reply #57 on: Sun, 03 March 2019, 16:07:18 »
Makes sense! I forgot to add that as an option in the strawpoll.  :-[
Offline KorbenDallas
Re: [IC] BnB87
« Reply #58 on: Sun, 03 March 2019, 18:55:32 »
I miss understood the cutouts strawpoll. I'd rather see brass in those areas as your renders show rather than pcb as well!
Offline Lbibass
Re: [IC] BnB87
« Reply #59 on: Mon, 04 March 2019, 08:58:28 »
yeah, I forgot that option in the strawpoll. :(
I think that's the best thing to go with right now. The pcb isn't fantastic, and a lot of traces run straight above the arrow keys. Hence, a solid brass plate in those areas is gonna be the best bet.
Offline Water lee
Re: [IC] BnB87
« Reply #60 on: Mon, 04 March 2019, 14:19:24 »
Nice pc case !
Render looks awesome
make it better!
Offline Lbibass
Re: [IC] BnB87
« Reply #61 on: Mon, 04 March 2019, 16:37:49 »
Nice pc case !
Thanks! I only did the top two renders, Tesletron did the ones you see below those two. He's much better at renders than I am.
Offline Lbibass
Re: [IC] BnB87
« Reply #62 on: Tue, 05 March 2019, 07:53:41 »
Offline vicissitude
Re: [IC] BnB87: Gasket Mount TKL
« Reply #63 on: Tue, 05 March 2019, 08:28:08 »
PC case is really attractive.
Love it.
Offline Lbibass
« Reply #64 on: Tue, 05 March 2019, 11:13:23 »
Love it.
Offline Remsky
  • Lubed switch count > Puddsy post count
« Reply #65 on: Tue, 05 March 2019, 18:59:27 »
nice
TGR Jane v2 - GSKT00(coming) - TGR Jane CE V2 - TGR Poly alice - LZ Physix - Matrix 8XV 2.0 - RS - LZ FE - Dalco 959 Mini GT edition (coming) - Mc65 - Hiney TKL one - HHKB Pro 1 - 25th anniversary edition HHKB pro Hybrid - 30th anniversary Filco 2S keyboard
Offline Lbibass
« Reply #66 on: Wed, 06 March 2019, 17:15:44 »
nice
Glad to hear you like it, Remsky!
Offline Windeh
  • a no name
« Reply #67 on: Fri, 08 March 2019, 07:28:37 »
Offline reidd
« Reply #68 on: Fri, 08 March 2019, 14:36:10 »
am interest
edit: Any chance for PVD coatings for the plate (pref. silver, black?)
« Last Edit: Fri, 08 March 2019, 14:40:55 by reidd »
Offline bunanapeel
« Reply #69 on: Sat, 16 March 2019, 12:52:54 »
I would totally join the GB when it comes around.  This combines two types of cases that I want to try into one.  A PC case and a gasket mount case.  I am really excited for this one.  :D
Offline Lbibass
« Reply #70 on: Sat, 16 March 2019, 12:56:29 »
am interest
Sorry for missing this! Right now my plans are to have one option, which is sandblasted brass. That way, fulfillment will be significantly easier. I want to minimize the opportunity for mistakes in fulfillment on my part.
Offline Lbibass
« Reply #71 on: Sat, 16 March 2019, 12:57:07 »
Glad to hear it!
Offline Jurka
Re: [IC] BnB87
« Reply #72 on: Sun, 17 March 2019, 15:49:34 »
Nice pc case !
Correct me if I am mistaken but the PC case will have kind of a milky hue just like the E6.5 does, right? The renders show it to be clearer than it actually will be, right?
Tenkeyless and penniless.
Offline Lbibass
Re: [IC] BnB87
« Reply #73 on: Sun, 17 March 2019, 19:26:46 »
Nice pc case !
Yup, it should be similar in aesthetics to the e6.5!
Offline Damage
« Reply #74 on: Sun, 17 March 2019, 21:11:14 »
Definite interest here.
Offline Damage
« Reply #75 on: Sun, 17 March 2019, 21:30:05 »
[Dupe removed. Doh!]
« Last Edit: Sun, 17 March 2019, 21:34:55 by Damage »
Offline Lumenoctis
« Reply #76 on: Tue, 19 March 2019, 04:50:59 »
Hi there! Extremely new to this forum so excuse me if I'm not following some sort of procedure, but I'm definitely interested in this case. Would you be supplying the PCB as well? I was thinking about purchasing Hineybush's h87alps board but if you're already supplying the PCB, I guess I wouldn't need to!
Offline Lbibass
« Reply #77 on: Tue, 19 March 2019, 21:42:00 »
You're all good! ALF will be supplying the PCB for this board. It's mid mounted USB-C. There's a lot of other cool features in this PCB too, like an SMD mounted RGB caps lock LED. Expect the PCB outline to be open sourced too, if not the entire PCB. Unfortunately I'm not the designer of the PCB, so I don't know if it'll be possible to open source all of the PCB.
Offline mrboli
« Reply #78 on: Wed, 20 March 2019, 14:36:02 »
For cutouts, you need to put no cutouts as option!
KBD67 Zealios V2 65g | HHKB Pro 2 | Filco TKL MX Black | Razer BlackWidow
Offline Lbibass
« Reply #79 on: Fri, 29 March 2019, 11:01:37 »
Yup, that was a mistake. I have decided to go with no cutouts. I prefer the aesthetic of the brass underneath the polycarbonate than the PCB.
Offline Jurka
« Reply #80 on: Fri, 29 March 2019, 13:20:40 »
Great choice imo. Also, I've read about polycarb finishes in the THINK6.5 interest check thread. Any thoughts about possibilities?
Offline Mr.Elli0t
« Reply #81 on: Sat, 30 March 2019, 14:55:22 »
The wait is killing me!!! Those renders are exactly how I want it and this is one of 2 that I definitely want  :D
Offline sadmachine
« Reply #82 on: Mon, 01 April 2019, 01:35:01 »
The space between Esc and F1 appears noticeably wider than the other F row breaks, as I see often in renders. Will this be the same on the physical case?
« Last Edit: Mon, 01 April 2019, 02:26:56 by sadmachine »
Offline TuCZnak
« Reply #83 on: Mon, 01 April 2019, 07:04:23 »
That is the standard layout, F1 directly over 2 with 1u between Esc and F1 and then 0,5u between F blocks themselves.
Offline tentboy
« Reply #84 on: Mon, 01 April 2019, 08:21:27 »
I think i'd join this  :)
Offline sadmachine
« Reply #85 on: Tue, 02 April 2019, 02:46:49 »
Thanks for confirming for this noob.  :)
Offline h0tdog
« Reply #86 on: Tue, 02 April 2019, 14:18:54 »
I'm probably down
Offline Bahm78
    • https://blog.naver.com/hjg7808
« Reply #87 on: Tue, 02 April 2019, 21:17:52 »
Oh very interesting
Offline Mr.Elli0t
« Reply #88 on: Thu, 04 April 2019, 11:12:02 »
Is it normal for it to take this long for pricing  :eek: the wait is deadly to me
Offline ramnes
  • T fou, mec?
« Reply #89 on: Thu, 04 April 2019, 16:02:59 »
interested
Offline Lbibass
« Reply #90 on: Thu, 04 April 2019, 19:30:19 »
Is it normal for it to take this long for pricing  :o the wait is deadly to me
Hey, sorry about that! I missed this. Anyways, I updated the post. Pricing updates. Still working everything out, including the possibility of custom boxes. pricing is still up in the air.
Offline Lbibass
« Reply #91 on: Thu, 04 April 2019, 19:30:35 »
Offline clik_clak
« Reply #92 on: Thu, 04 April 2019, 19:34:06 »
With how poorly ALF boxes have gone in the past (ie. month long delays to fix the boxes for the Renova X3, please don't do custom boxes.
If anything I've learned from the ALF GB's I've participated in, keep it as simple as possible expect MASSIVE delays and expect a product that won't fully meet your expectations (at least on the first try).
Offline Lbibass
« Reply #93 on: Thu, 04 April 2019, 20:15:52 »
Thanks for letting me know about that. Right now, ALF seems to have learned a lot, and has moved to a new location too. I'd like to see how he'll do this time.
Offline Mr.Elli0t
« Reply #94 on: Thu, 04 April 2019, 20:37:33 »
Thanks Lbibass! Super excited for the keeb! Save one for me !
Sent from my ONEPLUS A6003 using Tapatalk
Offline Harnak
« Reply #95 on: Thu, 04 April 2019, 20:41:16 »
Glad that you got pricing info from Alf! Super excited for this board, really digging your designs! <3
Offline Lbibass
« Reply #96 on: Fri, 05 April 2019, 08:11:57 »
Thanks for the encouragement! Hopefully some of my designs should start to move faster than the UEK and this one.
Offline wt5now
« Reply #97 on: Mon, 08 April 2019, 02:51:22 »
What is the basic plate? Brass? Aluminum? PC? Are there some options?
Offline Lbibass
« Reply #98 on: Mon, 08 April 2019, 08:03:48 »
The basic plate is Brass. There won't be a whole lot of options. Mainly just MX/alps, and a halfplate or a full plate for MX.
Offline kookiemunstur
« Reply #99 on: Tue, 09 April 2019, 20:09:06 »
This looks great, I'm deciding between this and the KBD8X MKII but leaning more towards this due to gasket mount, Would you also do a matching numpad in the future?
