Author Topic: [GB] Duck Orion V3 Kustom Keyboard - Complete!  (Read 232208 times)
Offline dubious
  • 쏘쿨
Re: [GB] Duck Orion V3 Kustom Keyboard - Complete!
« Reply #400 on: Fri, 04 October 2019, 18:54:33 »
I have worked with Marcus aka Keebology to get the Orion V3 into QMK. I have just submitted the preliminary firmware to QMK.
Switch matrix works correctly however I am still unsure about the lighting, once its merged through and available on QMK Configurator, please help me test =)
https://github.com/qmk/qmk_firmware/pull/6892
Wicked! Thanks Merlin!
Offline vaughno
« Reply #401 on: Sat, 05 October 2019, 09:58:05 »
Anyone have a fr4 plate and extra pcb that I could buy?
Unikorn | Orion v3 | GSKT-00
Offline merlin64
    • MechMerlin
« Reply #402 on: Sat, 05 October 2019, 10:17:23 »
Folks, Configurator link for QMK is up
https://config.qmk.fm/#/duck/orion/v3/LAYOUT_tkl_ansi
Please report back any bugs or additional features you would like to see.
Offline iEatPuppers
« Reply #403 on: Tue, 08 October 2019, 08:46:30 »
Thanks for doing this mate.
I tested out a layout on my v3 pcb, and there are issues with the lighting. Scroll lock is triggering the a layer indicator led; I'm not sure if caps lock does the same as I haven't soldered the rest of the layer indicator led's. None of the lock indicators seem to be triggering.
Here's a comparison between the orion pcb and h87a when both the caps and scroll lock are on:
https://imgur.com/a/xbWQXcW
Offline merlin64
    • MechMerlin
« Reply #404 on: Tue, 08 October 2019, 08:56:23 »
Yep, I did not implement any lighting. Whatever lighting is happening there is going to be random.
I was doing this remotely from the West coast, whereas Keebology is on the East. Last we chatted it seemed he had some lighting support working so we shall see when he puts that in.
Offline kalabeck
« Reply #405 on: Fri, 11 October 2019, 09:27:02 »
If anyone has a spare PCB to sell me, please let me know! I was a bonehead and only ordered one, and it's faulty (surge protection got triggered when I plugged it in to my PC...) It looks fantastic all done up, I'd hate for this to go to waste.
227931-0
Edit years later: Thanks vaughno for the heads-up about the H87 PCB! I've snagged one
« Last Edit: Sun, 13 June 2021, 13:55:34 by kalabeck »
Offline vaughno
« Reply #406 on: Mon, 14 October 2019, 19:07:33 »
Found a plate / pcb, thanks.
« Last Edit: Sat, 13 June 2020, 15:21:39 by vaughno »
Offline Smoff
  • 817 785
    • Youtube
« Reply #407 on: Tue, 15 October 2019, 18:42:50 »
H87 gb in  <2 weeks iirc if you can't find a pcb
Current boards: Matrix 1.2 OG | Matrix 8xv2.0 | Cherry g80-1000 | Cherry g80-3000 | Matrix 2.0add | Matrix Noah
Boards on the way: Duck Orion v2.5 | Matrix Falcon
Previous boards: BOK.CP | Duck Orion v3 | Mech27v2 | HHKB pro2 x3 | Cherry g80-11800 | NIU mini | Klippe r1 | Brutal60 | Duck Unicorn x Legend | Duck jetfire | Cherry g80-1800 | IDB60 | PC Salamander | Lin Whale r2 | LZ Physix | Duck Viper v3 |
Offline Carlobv
« Reply #408 on: Fri, 18 October 2019, 14:21:25 »
does anyone know how to change the leds from the default without reflashing?
Offline SeeNoEvo
« Reply #410 on: Wed, 06 November 2019, 00:49:14 »
MD socketed and lubed Holy Pandas, lubed screw-in stabs, SA Modern Selectric caps.
Looks great! That's a set you don't see often.
Offline vaughno
« Reply #411 on: Sat, 23 November 2019, 14:56:30 »
What size LED’s and where should I buy leds from?
« Reply #412 on: Sat, 23 November 2019, 15:51:39 »
1.8mm, literally any electronics supplier
unless you're talking about underglow, which i believe is ws2812b
Offline vaughno
« Reply #413 on: Sat, 23 November 2019, 15:59:23 »
Thank you.
Offline maxenth
« Reply #414 on: Sun, 19 April 2020, 00:40:14 »
Hi! when is the next batch coming?
Offline maxenth
« Reply #415 on: Sun, 19 April 2020, 00:41:34 »
Hi! when is the next batch coming? :(
Offline higgga
« Reply #416 on: Sun, 19 April 2020, 02:07:51 »
Don't expect this board to be run again. It's possible that V4 can happen in a few years.
Offline chowbabyloving
« Reply #417 on: Wed, 20 May 2020, 00:08:31 »
Any chance for an international Orion v2.5 gb?
Offline NightFox99
« Reply #418 on: Tue, 30 November 2021, 09:04:43 »
Hey,
Can anyone explain me how to control RGB lights on Orion V3 ? I flashed with QMK but the hotkeys governing the RGB won't work (lights are on but I can't change 'em : mode and intensity).
Please help !
