Author Topic: 1.75u row 4 SA Keycap  (Read 4873 times)
Offline Kavik
« on: Wed, 12 December 2018, 15:38:09 »
Since I don't have a 1.75u right shift for SA 1965, I had been using an upside down CAPS LOCK key from SA Carbon on my 1800 layout keyboard for my right shift key until I sold that set.
Now I need a 1.75u row 4 SA keycap to cover this switch. It would be awesome if it were from SA 1965, or even the same color brown, but I really don't care as long as it fills the gap.
I checked for blanks on pimpmykeyboard.com, but it has 1.75u keys in every profile except SA.
Is there any way to get a keycap to cover this switch without buying a Tsangen kit from some other GB and paying an arm and leg?
Yes, I am one of those weirdos who actually uses the right shift key. I press it when I capitalize a key on the left side of the keyboard, and I use it a lot in combination with the arrow and nav keys for highlighting text. I've been pressing the bare switch for weeks.
Offline Kavik
Re: 1.75u row 4 SA Keycap
« Reply #1 on: Tue, 22 January 2019, 12:57:32 »
I'm not sure if I was just too stupid to click on the link to the second page in this product list or if it was added later, but I found what I need. It's just out of stock.  :'(
https://pimpmykeyboard.com/sa-1-75-space-pack-of-4/
