Author Topic: Magic Eraser and the AT-F  (Read 6541 times)
Offline skcheng
    • Tenafly Dentistry
« on: Sun, 09 May 2010, 10:50:41 »
I know that this has been mentioned before, but I figure this is worth rementioning.   As most here know, I happen to be a clean freak.   Clean and vintage are often contrasting terms.
I've tried just about everything now to clean keys, frames, covers, cords etc...   Why people used to place stickers and use ink pens on their keyboards is beyond me??   I had mentioned at some point that aggressively cleaning the painted metal casing of my much loved AT-F boards is not a good idea.   I've managed to remove paint into primer and down to metal.  No biggee since my friendly neighborhood body shop will prime/paint the thing for me, but lesson learned.
I wish I had taken "before" pictures, but the seller of this board mentioned that the keys are a 9/10, but that the case is about a 6.5/10.   I think that was conservative, but there were multiple scuff marks, ink stains, and other non descript black streaks that just wouldn't come off with the usual chemicals.   Simple Greeen, Orange Solvent, 409, alcohol etc....
So enter this product:
Wet slightly, and scrub.  That's it.   Here is my AT-F after about 5 minutes of light clean up.  I'd say this board is at least a 6.75/10 now LOL.  Great stuff and stupid simple which is how I like it.
On to the pics:
Do NOT scrub that metal IBM plate.  The letters will come off if you're not careful.   I use a diaper wipe to lightly clean and that's it.  So far that's been safe and it leaves a nice fresh scent.
Enjoy,
skc
« Last Edit: Sun, 09 May 2010, 11:59:39 by skcheng »
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #1 on: Sun, 09 May 2010, 12:04:13 »
Worth mentioning but not deserving of its own thread: I've had success using a metal-bristle golf ball brush on plastic Model M cases. You'd (and I did) expect it to scratch the plastic but no, strangely it doesn't...just takes off pen writing and tough dirt.
kishy.ca
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #2 on: Sun, 09 May 2010, 12:15:36 »
You can clean just about anything with a Mr. Clean Magic Eraser.
Offline ch_123
« Reply #3 on: Sun, 09 May 2010, 15:16:14 »
Heh, Mr. Clean. Funny to see how brands vary from region to region.
In the UK and Ireland, he's called Flash. If memory serves me correct, I've seen him branded in Spain and Italy as Mr. Proper and Mastro Lindo respectively.
« Last Edit: Sun, 09 May 2010, 15:46:29 by ch_123 »
Offline nowsharing
  • Swoop
« Reply #4 on: Sun, 09 May 2010, 15:43:39 »
I'll have to try the magic eraser. One of my boards has tiny drops of india ink or black paint all over it. Nothing so far has phased it. I ended up trying finger nail polish, which just formed larger black smudges.
That's my story.
Offline didjamatic
« Reply #5 on: Sun, 09 May 2010, 15:52:12 »
Haha, I didn't know anyone had posted using magic erasers here before.  I use them when refurbishing all kinds of things and I would never have been able to get my clean Cherry Ivory board back to Ivory without it.  It's the single dirtiest board I ever got and you'd never know it by looking at it, it's clean as can be.  Did you know you can even remove some yellowing with a magic eraser?  Because it takes off an ultra thin coat of the plastic/paint/whatever your'e cleaning, but without grinding deep into it, you can actually whiten some things up a bit.
SKC, that is one awesome clean job on that ATF.  Nice work as always.
Offline Mercen_505
« Reply #6 on: Sun, 09 May 2010, 17:50:53 »
Magic Eraser works wonders on keyboards. However... on my model F AT there is a spot where the surface has been scraped away to reveal a light gray plastic. I thought it was just dirt, but after a thorough scrubbing I noticed the spot was growing as I scraped away even more plastic with the eraser! I don't think the model M suffers from that, as I have one with a deep gouge and there isn't any darker plastic underneath.
Offline skcheng
    • Tenafly Dentistry
« Reply #7 on: Sun, 09 May 2010, 17:53:44 »
Quote from: webwit;180480
So it's a micro-polisher. I use the professional stuff, not consumer grade. Nah, I bet it is all the same, and what sets 'em apart is branding and marketing.
Have you tried the Magic Eraser??  You'd love it.  If you can't find some there, let me know and I'll send you some.
Offline skcheng
    • Tenafly Dentistry
« Reply #8 on: Sun, 09 May 2010, 17:56:41 »
Quote from: Mercen_505;180502
The AT F isn't molded plastic like the Model M.  It's paint, and then primer over that top case.   A deep gouge can't be cleaned up.   But scuffs, ink, dirt can wipe away with the Magic Eraser.   That's why a deep scratch will show silver on the AT F.  Or if you're hyper aggressive cleaning the AT F, you can manage to go right through the paint.
Offline skcheng
    • Tenafly Dentistry
« Reply #9 on: Sun, 09 May 2010, 18:11:08 »
Quote from: webwit;180517
What's in it? I have a feeling it's the same thing.
I don't know what's in it.  That's why it's Magic  :)
Offline nowsharing
  • Swoop
« Reply #10 on: Sun, 09 May 2010, 18:16:22 »
The F's are painted IIRC, so there's more of a chance of damaging them when cleaning.
edit: I missed skcheng's post above. Sorry for the redundancy.
Offline Mercen_505
« Reply #11 on: Sun, 09 May 2010, 19:39:53 »
Magic Eraser is melamine foam (micro-abrasive) soaked in ammonia and probably some other stuff as well. Add a little water, then start scrubbing!
Offline skcheng
    • Tenafly Dentistry
« Reply #12 on: Mon, 10 May 2010, 06:58:48 »
Quote from: ripster;180555
I like  Novus plastic polish.
Can also restore scratched DVDs/CDs.
Three steps??  Ackk.
Offline didjamatic
« Reply #13 on: Mon, 10 May 2010, 10:48:51 »
I only use magic erasers dry, no water or cleaners.  They are amazing.  I have young kids and markers/pens/etc in the house and magic erasers have saved their lives repeatedly.
Offline mrbill
    • http://weblog.mrbill.net
« Reply #14 on: Mon, 10 May 2010, 23:38:16 »
Quote from: webwit;180709
Does anyone know, what's the stuff you can buy to remove scratches from iPods and such, and is it useful?
I've bought the specialty stuff, but it's easier to just buy a can of Brasso and use it sparingly; you get the same result.  I've used the same can of Brasso for 5-6 years now and used it to polish out scratches before sending iPods and phones to their new owners.
http://en.wikipedia.org/wiki/Brasso
Keyboards:
IBM Model Ms: 51G8572 (\'94, \'96), 1391401 (\'90), 1369050 (\'95, Dell), 1394946 (\'89 Industrial)
Unicomp Model Ms:  Customizer 104, SpaceSaver 104
Chicony: KB-5181, KB-5191
Cherry:  MX11800 (x2), G86-6241 "Ricercar SPOS"
Filco: FKBN87M/EB x2, Cherry Browns
Sold: Matias Tactile Pro 1.0 (x2), Kensington Studioboard Mechanical, Scorpius M10, AEK II (x2), Compaq 11900 (x2), IBM Model F (AT), Filco FKB104MC/EB
Available Free for Cost of Shipping: ABS M1, Solidtek KB-6600ABU, KeyTronic KB101Plus
Offline ricercar
  • mostly abides
« Reply #15 on: Tue, 11 May 2010, 00:10:48 »
Brasso is awesome stuff. I use it to polish scratches out of optical discs.
Offline Rajagra
« Reply #16 on: Tue, 11 May 2010, 05:13:10 »
Quote from: ricercar;180889
Yes, they did a thorough test that compared the ECC results on CDs 'cleaned' with various methods, and Brasso did the best job of removing scratches.
Offline itlnstln
« Reply #17 on: Tue, 11 May 2010, 09:19:53 »
I have mine in a silicone case.  The silicone is tits.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #18 on: Tue, 11 May 2010, 12:35:16 »
I recommend polishing iPods with one of these:
kishy.ca
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #19 on: Tue, 11 May 2010, 12:55:13 »
Ah, I see you've done this before.
Works great, doesn't it?
kishy.ca
Offline itlnstln
« Reply #20 on: Tue, 11 May 2010, 13:01:03 »
I used webwit's process just now.  It makes everything look a little... flat.
Funky!
Offline skcheng
    • Tenafly Dentistry
« Reply #21 on: Tue, 11 May 2010, 13:10:17 »
Quote from: itlnstln;181092
Funky!
I LOVE Telefunken.  They make some of the best audio vacuum tubes EVER!!!
And the quality of their lps isn't bad.  Not much music on one of those 10" lps though.
Offline itlnstln
« Reply #22 on: Tue, 11 May 2010, 13:14:14 »
I have a few albums made by them, too.  I like to listen to them at home.
Offline EverythingIBM
« Reply #23 on: Tue, 11 May 2010, 22:03:24 »
Can it really fill in scratches on CDs? Some of my DOS games could use a bit of fixing up; as a child I often carelessly left my CDs to be openly scratched.
