Author Topic: Keyboard 20 cm width max.  (Read 2627 times)
Offline Entropia
« on: Sun, 16 December 2018, 03:27:52 »
I need a small and economical keyboard, not wider than 20 cm, wired and with cursor keys. It doesn't have to be mechanical. It's just for a very specific use in a place where space is very limited.
Offline RominRonin
Re: Keyboard 20 cm width max.
« Reply #1 on: Fri, 28 December 2018, 10:31:59 »
The Planck (OLKB.com) is approximately 23 cm, it's already quite compact and requires a major adjustment in typing habit to get used to.
The Atreus42 is available from Falba.tech, that's about the same size but has a slightly different layout.
There are smaller boards, but I can't tell you what they're called. I'm sure others here can list names off for you.
Those are your mechanical options. There are plenty of compact keyboards made for tablets that you can consider. You can google iPad mini keyboard and you'll get a host of online links.
Good luck finding what you're after.
« Reply #2 on: Fri, 28 December 2018, 11:11:37 »
I would look among tablet and HTPC keyboards. Many of those are smaller than standard.
HTPC keyboards often have a touchpad built-in also though.
