Author Topic: IBM Model M LED Overlay Sticker WANTED ...!!  (Read 3891 times)
Offline ZX Spectrum
« on: Sun, 16 December 2018, 06:00:21 »
I would like to buy GENUINE ibm model m led overlay stickers.
I know that Unicomp sell them but I am interested in original IBM-made ones.
According to my information, 1390131 used to be shipped with extra led overlay stickers sealed in small plastic bag, I would love to buy such sealed bag.
so if any one happens to have those stickers, I very interested in buying them
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
Re: IBM Model M LED Overlay Sticker WANTED ...!!
« Reply #1 on: Sun, 16 December 2018, 11:00:48 »
Huh? They are OEM stickers. The pebble overlay ones are the original stickers for the IBM keyboards.
As indicated by the picture, on the left side...
OEM Terminal, OEM 42H (4th gen) and 139 (3rd gen or older) keyboard overlays are indicated.
I hope this helps.
« Last Edit: Sun, 16 December 2018, 11:02:54 by Snowdog993 »
Offline ZX Spectrum
« Reply #2 on: Sun, 16 December 2018, 11:16:33 »
I hope this helps.
yes but I am not sure about the quality of Unicomp-made stickers, those ones shown in your pic are still Unicomp-made, right ??.
 I am afraid that, just like everything Unicomp makes, they would have low quality.
to have IBM-grade ones is very important as they will be used for an attempt to convert 1390120 to 1391401
Offline no, the other guy
  • actually, this guy
« Reply #3 on: Sun, 16 December 2018, 11:35:09 »
Unicomp does not really **** up stickers. They only fail to place them correctly (see my review) if they come with the keyboard. :)
<armin> i have the impression the only reason the mx red switch was invented was drunk people
Unicomp PC122 (review) * IBM Model F XT * Dell AT101W
Offline Snowdog993
« Reply #4 on: Sun, 16 December 2018, 15:03:31 »
Those ARE stock IBM overlays in the Unicomp warehouse. If you like, find an old 1401 and take the sticker off carefully and compare them. I never saw any difference. It's your money.
Offline Snowdog993
« Reply #5 on: Sun, 16 December 2018, 15:19:14 »
I hope this helps.
ARRGH! What does it take to convince you of anything?
« Reply #6 on: Mon, 17 December 2018, 17:33:28 »
Huh?
I would transplant the 120 back plate into the 401 internals and consider it an upgraded 401. Purity will not be a characteristic of your Franken-board in any case.
Unicomp makes stickers overlays with light holes top and light holes bottom. Their quality is entirely reasonable.
edit: sorry, I was using improper terminology. to me, a square metal thing is a badge, and everything else is a plastic sticker.
« Last Edit: Mon, 17 December 2018, 17:42:03 by fohat.digs »
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
Offline Snowdog993
« Reply #7 on: Mon, 17 December 2018, 17:35:50 »
Huh?
Unicomp makes stickers with light holes top and light holes bottom. Their quality is entirely reasonable.
Fohat: he was talking about the LED Overlays.
