Author Topic: HHKB Spacebar Silencing with Tribosys 3204  (Read 2332 times)
Offline jackwong343
« on: Sun, 16 December 2018, 07:58:54 »
Hi Guys,
I am thinking to lube my HHKB Type-S spacebar as it sounds pretty off. I do not have any dielectric grease with me at the moment, would Tribosys 3204 work on the stabilizers and housing of the spacebar?
As so far, most I read are just using it for the stems and rails.
Thanks for the advice!
Offline ArchDill
Re: HHKB Spacebar Silencing with Tribosys 3204
« Reply #1 on: Sun, 16 December 2018, 10:08:09 »
It is worth a try!
I have used super lube and normal lube on mine. Every couple of months I go back with some thin lube and put in the stabs. It took me so long to figure out a way to get my SB to be more quiet on my hhkb.
Offline Polymer
« Reply #2 on: Mon, 17 December 2018, 21:19:01 »
P B T Spacebar
