Author Topic: IBM / Lexmark M2 Keyboard PCB pinout  (Read 5637 times)
Offline m3741
« on: Mon, 17 December 2018, 09:50:33 »
Hello fellas, first post!
I found an old IBM M2 of mine in my grampa's attic; Its cord is missing, but overall all pieces are there.
I'm working on restoring it and have already replaced the capacitors [which were most likely dead].
All I need to get this bad boy working again is to know where which of the pins in the PCB go to in the ps/2 plug.
Could any one of you fine lads tell me which is the Ground, Clock, Data and 5v pins?
Here is a picture of me holding my keyboard's PCB:
Here is the plug I have that goes into the PCB:
I'm inclined to believe that red is 5v, black is ground, yellow is clock and white is data, but I don't want to take any chances and fry my only board.
I appreciate you help!
Thanks a lot!
Offline Tactile
Re: IBM / Lexmark M2 Keyboard PCB pinout
« Reply #1 on: Mon, 17 December 2018, 11:52:44 »
I can't answer all of your question but I can tell you that power & ground are the only critical wires. If you can identify the power & ground and get them wired up correctly, you can mix 'n' match the other two wires. The data and clock can be connected backwards without consequence. If the keyboard doesn't work, just swap those two wires.
REΛLFORCE
Offline m3741
« Reply #2 on: Mon, 17 December 2018, 12:11:26 »
I'm assuming that red and black are 5v and ground respectively, but its just an assumption.
Any how, thank you very much for your reply, now my quest has narrowed down to just figuring out if the red and black wires are respectively, 5v and ground.
Offline ErgoMacros
« Reply #3 on: Mon, 17 December 2018, 13:03:29 »
Someone else probably knows definitively, but one of the pins likely is connected directly to the large flat areas (ground plane), so that would be ground. Check for continuity.
Today's quote: '...“but then the customer successfully broke that.”
« Reply #4 on: Mon, 17 December 2018, 17:39:14 »
IBM was never consistent, and  NEVER TRUST COLOR  but this is the scheme for the Model F 122-key terminal:
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
Offline m3741
« Reply #5 on: Mon, 17 December 2018, 18:00:58 »
Holy balls, dude! Thank you so very much for the heads up!
Well, I guess I'm back to square one on this again... Better safe than sorry.
Offline m3741
« Reply #6 on: Tue, 18 December 2018, 09:33:21 »
I'm at a point that I'm willing to pay for this information.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #7 on: Tue, 18 December 2018, 10:13:34 »
Red - +5V
Blk - GND
Wht - CLk
Yel - Data
Like it helps....
Offline m3741
« Reply #8 on: Tue, 18 December 2018, 16:08:35 »
Thank you for your reply.
No one wants more than I do for this to be 100% accurate.
Are you 100% sure on this, do you own the same keyboard?
I mean, can I bet my single board on this info?
Please don't get me wrong, I'm in no way doubting your intentions in helping me out on this issue.  My skepticism mainly comes from the earlier post regarding another IBM keyboard model whose wire colors were completely different.
Offline Snowdog993
« Reply #9 on: Tue, 18 December 2018, 20:06:23 »
The only thing is to be sure the pins correspond to the pins on your PS/2 plug as well. If you are using a "generic" PS/2 cable, the colors may not correspond to the pins. Just be sure that is correct. I don't see a problem with it, but if you do, find another person with an M2 that may tell you exactly what it actually is.
EDIT:
I would verify with another M2 if I had one. But I don't and the best solution I see is to actually compare a working M2 keyboard with the connector. There are a lot of different wiring diagrams for the IBM Model M and M2. The Lexmark chipset may or may not correspond to the actual pinouts.
This is a guess on my part. I can't verify it so I can't say it's accurate.
« Last Edit: Tue, 18 December 2018, 20:27:21 by Snowdog993 »
Offline Snowdog993
« Reply #10 on: Tue, 18 December 2018, 20:28:22 »
Read my edit.
Fohat is correct in telling you to not trust the colors but the pinouts could very well match/not match. I spent some time looking at my resources and couldn't find anything pertaining to the M2. Sorry about that. All I did was guess.
« Last Edit: Tue, 18 December 2018, 21:55:41 by Snowdog993 »
Offline invariance
  • ...here with all the other boson's
« Reply #11 on: Wed, 19 December 2018, 14:49:38 »
The only way to definitively know is to pull up a spec sheet for one of the ic’s to find the Vcc and gnd pins and use a multimeter to trace it to the header (connector).
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
Offline m3741
« Reply #12 on: Thu, 20 December 2018, 09:52:13 »
Sent an email to the fine folks at unicomp. Since they bought (I believe all) pattents from Lexmark and IBM keyboards, I'm hoping they have the schematics for this board.
Offline m3741
« Reply #13 on: Thu, 20 December 2018, 13:00:36 »
So... since I got no feedback from unicomp and all my google skills are not returning anything useful, I decided to investigate the board myself.
I noticed that one of the pins runs a very long trail all across the board and this trail goes through all positive poles of the leds (caps, num and scroll). So, without shadow of doubt that's the +5v pin, as we all know LEDs have a specific polarity to work.
It also turns out that this keyboard seems to follow the color scheme fohat.digs sent, as this pin is the one connected to the black wire.
Using a multimeter I was able to determine the ground pin, as it is the pin combination that gives less resistance.
That was another indication that this keyboard seems to follow the color scheme fohat.digs sent, as this pin is the one connected to the white wire.
As Tactile pointed out, mixing clock and data is not harmful, so, given that +5v and GND are folloqing fohat.digs' color scheme, I'll wire them up accordingly and I'll post the results here.
Wish me luck!!!
So far, thank you all very much!
Offline m3741
« Reply #14 on: Fri, 21 December 2018, 12:26:24 »
So, no luck, when I plug it in all I get is Caps and Scroll light up, then Num flashes really fast and they all turn off:
Results: Keyboard doesn't work.
I'm sure +5v and ground are wired correctly as otherwise the LEDs wouldn't turn on.
I've seen online that usually when that happens the capacitors on the board are dead, but I changed the capacitors on the board for brand new electrolytic capacitors (as you can see) with the same uf and voltage of the original ones.
I also tried switching the Data and Clock cables around, but no luck.
On Linux, kernel messages when I plug the keyboard to a USB port show:
Code: [Select]
[ 2015.119629] usb 2-2: new full-speed USB device number 38 using xhci_hcd
[ 2015.247696] usb 2-2: device descriptor read/64, error -71
[ 2015.483718] usb 2-2: device descriptor read/64, error -71
[ 2015.719621] usb 2-2: new full-speed USB device number 39 using xhci_hcd
[ 2015.847683] usb 2-2: device descriptor read/64, error -71
[ 2016.083646] usb 2-2: device descriptor read/64, error -71
[ 2016.191652] usb usb2-port2: attempt power cycle
[ 2016.843601] usb 2-2: new full-speed USB device number 40 using xhci_hcd
[ 2016.843920] usb 2-2: Device not responding to setup address.
[ 2017.051940] usb 2-2: Device not responding to setup address.
[ 2017.259586] usb 2-2: device not accepting address 40, error -71
[ 2017.387592] usb 2-2: new full-speed USB device number 41 using xhci_hcd
[ 2017.387909] usb 2-2: Device not responding to setup address.
[ 2017.595889] usb 2-2: Device not responding to setup address.
[ 2017.803569] usb 2-2: device not accepting address 41, error -71
[ 2017.804601] usb usb2-port2: unable to enumerate USB device
Any advice?
Tried two types of PS/2 adapters, those tiny converters that all they do is rewire the PS/2 wires to the USB and also tried the kind that have a circuit board in them and have two entries, one for PS/2 keyboard and another one for mouse.
None of them worked...
« Last Edit: Fri, 21 December 2018, 13:14:03 by m3741 »
Offline rich1051414
« Reply #15 on: Sat, 22 December 2018, 02:20:37 »
I cannot stress enough how you should NEVER trust wire colors on IBM keyboards. In the past I have accidentally read a female diagram as a male, and since the colors agreed, I just accepted that. BIG MISTAKE. Totally ignore the colors entirely, no matter how much it makes you question it.
« Reply #16 on: Sat, 22 December 2018, 08:21:01 »
That has tripped up a lot of people. The diagram clearly says facing the connector on the PCB. That socket will be the mirror image of whatever plug is on the end of the cable.
Offline m3741
« Reply #17 on: Fri, 08 February 2019, 12:52:39 »
Good news is: I got the keyboard working!!
YAY!
Turns out the problem I was having before was because of a faulty ps/2 to usb adapter.
So, for future reference, if anyone ever comes to this post looking for answers here is the pinout order as seen on the above pic, from left to right:
Pin1, yellow wire: Data
Pin2, white wire: Ground (sometimes called V-)
Pin3, red wire: Clock
Pin4, black wire: V+
Although Fohat.digs' diagram was for a different IBM keyboard, the wiring colors were spot on.
The PS/2 adapter I'm using that works shows up on Linux as:
"Holtek Semiconductor, Inc. PS/2 keyboard + mouse controller"
It looks like this in lsusb:
Code: [Select]
T430:~ # lsusb -vs 001:003
Bus 001 Device 003: ID 04d9:1400 Holtek Semiconductor, Inc. PS/2 keyboard + mouse controller
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x04d9 Holtek Semiconductor, Inc.
  idProduct          0x1400 PS/2 keyboard + mouse controller
  bcdDevice            1.43
  iManufacturer           0
  iProduct                0
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           59
    bNumInterfaces          2
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      1 Boot Interface Subclass
      bInterfaceProtocol      1 Keyboard
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength      65
         Report Descriptors:
           ** UNAVAILABLE **
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval              10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      2 Mouse
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength     157
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
can't get debug descriptor: Resource temporarily unavailable
Device Status:     0x0000
  (Bus Powered)
T430:~ #
It looks like this in real life:
Its sold under too many names and brands.
I'd like to thank you all for your help!
« Last Edit: Fri, 08 February 2019, 13:03:53 by m3741 »
Offline invariance
« Reply #18 on: Fri, 08 February 2019, 17:58:39 »
That’s excellent!
My Model M is behaving weirdly and needs fault finding too
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
