Author Topic: hexon38  (Read 6229 times)
Offline kbder
hexon38
« on: Tue, 18 December 2018, 01:05:43 »
Hello,
I've been working on a keyboard, which I'm calling the hexon38: https://github.com/pepaslabs/hexon38
It is yet another riff on a split ortho with a thumb row.  Here is a page of inspiration: https://github.com/pepaslabs/hexon38/blob/master/inspiration.md
Right now this project just consists of a few laserable PDF's made in CorelDraw and a hand-wired prototype.
I've just started working on the QMK firmware.  I had an idea for having the home-row keys double as SHIFT, GUI, ALT, CTRL modifiers (via QMK functions like LCTL_T()), but unfortunately those functions seem to be very sensitive to roll-over between keypresses.  I'll have to dig further into QMK to see if I can implement something more robust.
Offline macroxue
    • Darknight: DIY 60% Split Keyboard
Re: hexon38
« Reply #1 on: Tue, 18 December 2018, 16:14:01 »
It's a nice looking one! I assume you also have a cover for the controller.
With such an inward angle, can the shoulders relax well while you're typing?
Regarding dual-role keys, there were previous attempts but they didn't work 100%. One way is to let less frequently used keys take the second role. For example, it works well for me to put Ctrl and Esc on the same key.
« Last Edit: Tue, 18 December 2018, 16:26:02 by macroxue »
[Darknight: DIY 60% Split Keyboard](https://github.com/macroxue/keyboard-diy)
Offline algernon
  • A tiny mouse, a hacker.
    • Diaries of a Madman
Re: hexon38
« Reply #2 on: Wed, 19 December 2018, 06:49:53 »
I'd be very interested in a typing video on this board.
(Big +1 on using a wood frame. Wood is good. :))
