Author Topic: Does change the spring of switch impact tactility ?  (Read 10519 times)
Offline M_Sang
« on: Tue, 18 December 2018, 06:33:17 »
I am searching for a smooth round bump tactile switch.
but most good tactile switch seem to have high peak force more than my liking.
I come from using cherry mx brown (genuien one) that very light and so litte tactile. I try cherry mx black (I know it's linear) that already too heavy for me .
if I bought tactile switch with higher peak force and change the lower force spring , Does change spring of tactile switch to lower force impact the tactility ?
and Does it have any other effect?
Re: Does change the spring of switch impact tactility ?
« Reply #1 on: Tue, 18 December 2018, 07:37:08 »
Yes, switching to a stiffer spring will in general make the tactile event less noticeable.
In Cherry MX switches (and clones), the bump on a tactile slider will enact the same absolute difference in pressure with different main springs, but they will be different relative to the influence of main spring.
Offline M_Sang
« Reply #2 on: Tue, 18 December 2018, 10:25:00 »
Thank you
Offline ThoughtArtist
« Reply #3 on: Tue, 18 December 2018, 17:32:32 »
Yeah, people like the zealious (sp?) because they are essentially an MX Clear with a weaker spring, so the bump feels more pronounced due to less dampening I think
« Reply #4 on: Tue, 18 December 2018, 19:45:10 »
Zealios changed their slider for "Zealios V2", and they feel different now. Zealios (old and new) come in four spring weights.
Outemu purple is also like a lighter Cherry MX Clear.
Myself I like the weight of the regular MX Clear. The weighting and the force curve actually makes it easier to not bottom out.
Offline M_Sang
« Reply #5 on: Wed, 19 December 2018, 03:13:19 »
!? Does zealios weaker than mx clear?
The lowest option of zealios I see is 62 gram.(not sure bottom out force or tactile peak)
I use to used mx brown. And now hako violet.
That around  35-45gram peak tactile force.
I fear that other tactile switch would be too much for me.
Do you  have any recommendations on round bump tactile switch with low force peak?
« Reply #6 on: Wed, 19 December 2018, 11:09:30 »
Zealios are measured by bottom-out weight.
This graph measured of a Zealio purple V1 bottoms out at around 62-65 gf and the tactile peak is around 56 gf.
However, Zealio V1 are being discontinued in favour of Zealio V2, and I have not seen actual measurements of that yet. I have heard people say that the tactile even is higher up, and that would mean that it does not feel the same.
Anyway. I think that it is not the top force but the size of the area under the curve in the graph that determines how heavy it really feels. If a switch encourages you to not press too far, then you might not get too much of an area. But it depends greatly on your individual typing style.
« Last Edit: Wed, 19 December 2018, 11:11:17 by Findecanor »
Offline M_Sang
« Reply #7 on: Wed, 19 December 2018, 12:22:21 »
I know that the area under are actual force using to press to bottom.
the whole graph actually  tell a lot more but it's hard to find info on actual testing (not a simple version that provide by manufacturer)
Do you have source to more graph like this ?? (aside from the one in input club)
Offline Hypersphere
« Reply #8 on: Sun, 23 December 2018, 14:45:41 »
ZealPC switch "weights" refer to the bottom-out force rather than the actuation force. Tactility is a feature of tactile switches arising from a concerted increase and release of pressure due to a bump or cam on the slider (as in mx brown or clear), the added resistance of a tactile leaf (as in  SKCM orange Alps), collapse of a rubber dome (as in Topre), or the buckling of a spring (as in IBM buckling spring switches).
If the switch is purely linear (as in mx red or SKCL green Alps), increasing the spring weight increases the resistance but there is no tactile event, so tactility does not increase.
As others have noted, increasing the spring weight in the same type of tactile switch decreases the perception of tactility, because the relative change in resistance is less.
Cherry mx clears feel more tactile and heavier than mx browns because the tactile bump is bigger and the spring weight is greater. In my own case, I prefer to bottom-out my keypresses. Because clears have a rather high bottom-out force of 95g or so, I find clears too heavy.
I've tried ZealPC Zilent v1 67g and find them just about right with respect to tactility and resistance although maybe a bit too light. I have not yet tried v2. My understanding is that v2 Zilents have a more pronounced tactile bump that occurs at the top of the keypress and that the spring resistances are the same as before in the four grades that are offered (62, 65, 67, and 78g).
Offline M_Sang
« Reply #9 on: Thu, 27 December 2018, 22:49:58 »
thank , appreciate every input
Offline killyou
« Reply #10 on: Fri, 28 December 2018, 19:08:14 »
The weaker the spring the higher tactile feeling. Comparison in terms of MX Clear and Zealio tactility:
Zealio V2 62g>65g>67g>78g>Cherry MX Clear>Zealio v1 62g>65g>67g>78g
MX Clear is more tactile than Zealio v1. They use the same sliders but zealio is a bit pre lubed, less scratchy and doesn't have progressive spring like MX Clear which all adds to less tactility.
