Author Topic: Sculpting Molding Keycap (Now with Pressure Pot!)  (Read 7186 times)
Offline unluckyxiii
    • Instagram
« on: Thu, 27 December 2018, 16:27:40 »
There are so many talented artisan keycap makers out there but of cause not lucky enough to score everything. I’ve decided to try for myself and see if I can pull this off.
Gotten a $ynth 2.1 off MechMarket and did 2 sculpts using polymer clay from my wife.
Went on with making the silicone mold but without pressure pot is just impossible to not get any bubble.
I then do a multi shots resin.
Been super careful but you can’t escape the bubbles without pressure pot.
I stay in an apartment and I’m not sure how noisy is the compressor pump and if to run it for a prolonged time to cure resin will be even less tolerable.
Any advise and comments are welcome! Thanks!
« Last Edit: Mon, 04 February 2019, 04:09:41 by unluckyxiii »
Offline sinusoid
  • fd > ESC
Re: Sculpting Molding Keycap (Pressure Pot!?)
« Reply #1 on: Wed, 02 January 2019, 09:34:36 »
You can remove most of the bubbles without using a pressure pot.
For resin:
use slow setting resin, mix it in a larger container and set it away to let most bubbles escape.
You can vibrate the bubbles away, for example using a sanding oscillator powertool.
Draw the resin into a syringe by dipping it all the way down, so when you draw the piston no air gets in.
Do not let any air get into the syringe when drawing.
Inject the resin into the mold at the lowest point, slowly, preferably using blunt tip needle.
I grab the highest diameter needles available in the pharmacy, usually 0.8mm, and trim them with a dremel and a cutting disc to 2/3 length. This also decreases flow resistance.
Do not empty the syringe completely, because there is always a little air trapped on top - when you draw the resin in, the nozzle always has some air in it.
This will most likely not work for optically clear resins due to microscopic bubbles that won't be able to escape.
For silicone:
same as above, but it's hard to inject it via syringe due to its viscosity.
Pour it slowly from the container, keeping a very thin stream - this will pop most of the bubbles that remain. Pour into the lowest point. This can still form cavities on the undercuts, you can help it flow into the undercuts with a toothpick, a cotton swab, or a small brush.
You'll get much better results with a pressure/vacuum pot, though.
You can scavenge a cheap and silent compressor/vacuum pump from an air conditioner, or a refrigerator.
It works both ways, so you can use it as a vacuum pump and an air compressor.
There are a few tutorials on that floating around youtube.
I think there are commercial solutions based on these types of pumps as well.
You won't have to run the compressor for a long time - you just need to keep the pressure constant for the resin setting time.
Normal market-bought compressors usually have an intermediate air tank that gets pumped up to the compressor's nominal pressure, a pressure switch that turns the compressor on and off when the tank reaches certain pressures (max/min), and a pressure reducer, often with an integrated deoiler and dehumidifier.
The compressor will only turn on if you have a leaky pressure chamber, and the compressor will have to compensate. It will run for a bit to rise the pressure in the chamber to the maximum value, and turn off again.
For the pressure chamber itself I recommend this thread:
https://geekhack.org/index.php?topic=96853
Cheap, scaleable, and very very fast.
You can also use centrifugal casting as an alternative:
It comes with its own issues though.
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #2 on: Wed, 02 January 2019, 09:40:42 »
LEMME AT 'EM
Offline dgneo
  • Supervillain
« Reply #3 on: Wed, 02 January 2019, 09:41:03 »
That spongebob is ****ing fantastic
Offline unluckyxiii
    • Instagram
« Reply #4 on: Sat, 05 January 2019, 20:07:11 »
For resin:
For silicone:
Thanks for all the tips! I shall try it in the next run.
Offline unluckyxiii
    • Instagram
« Reply #5 on: Sat, 05 January 2019, 20:10:01 »
LEMME AT 'EM
Let me get it right first hahah
Offline unluckyxiii
    • Instagram
« Reply #6 on: Sat, 05 January 2019, 20:10:20 »
Offline lovechan
    • HLZZ Keycaps
« Reply #7 on: Fri, 11 January 2019, 20:54:47 »
looks cool.
Offline unluckyxiii
    • Instagram
« Reply #8 on: Fri, 11 January 2019, 20:57:05 »
looks cool.
Thank you. I’ve decided and currently looking at air compressor and pressure pot.
Offline ArchDill
« Reply #9 on: Fri, 11 January 2019, 20:58:56 »
These are so rad. You are talented.
Good luck! Excited to see what comes of these.
Offline unluckyxiii
    • Instagram
« Reply #10 on: Fri, 11 January 2019, 20:59:45 »
Thanks for the kind word!
Offline unluckyxiii
    • Instagram
Re: Sculpting Molding Keycap (Now with Pressure Pot!)
« Reply #11 on: Mon, 04 February 2019, 04:14:17 »
I’ve eventually went ahead purchasing the air compressor and pressure pot and gotten good result!
