Author Topic: Custom Keycaps/ where to  (Read 3391 times)
Offline Ridingmac
« on: Sat, 29 December 2018, 00:34:48 »
Im planning my very first build (handwired). Ive made my Layout. Ive started saving up for case, switches, custom cut plate from lasergist. Only thing im missing is keycaps.
Im been googling the past hours and could not find an answer. Im wondering if theres a site out theres to makes custom keycap set. Where i could send a template
and have a set made with custom printing?? Im not gonna have a standard layout and would have to order some odd keycap to finish this.
I havent figuered out my color scheme but it would be something like this.
209619-0
Re: Custom Keycaps/ where to
« Reply #1 on: Sat, 29 December 2018, 01:55:22 »
WASD do custom keycaps, although you'd have to mix and match to get a set that would suit your layout.
http://www.wasdkeyboards.com/index.php/products/keycap-set.html
Offline Ridingmac
« Reply #2 on: Sun, 30 December 2018, 10:18:40 »
Gotcha thanks a bunch. Ill look into it
Sent from my SM-G960W using Tapatalk
