Author Topic: Otaku with print on side?  (Read 1625 times)
Offline Infinite north
« on: Mon, 10 May 2010, 20:00:48 »
I am wondering if blank key tops with regular key function printed on side exists anywhere. I understand that the idea is to clean up the keyboard and that the user should know where everything is located. I like that a lot but there are times when I want to know what I am pressing and I wouldn't want otaku alpha's and printed everything else. While I am sure the best suggestion anyone will have on the subject is to talk with a key manufacturer I thought I would see what you knowledgeable folks have to say.
Offline washuai
    • http://home.earthlink.net/~haruai/
« Reply #1 on: Mon, 10 May 2010, 22:23:30 »
Trial and Error, the cheapest/fastest way to learn.
Super sneaky spy sublimated dyed glow in the dark lettering.  Flash an ultraviolet desk lamp and bam, those hidden letters/symbols shine and it is more intrigue than an illuminated with the lights off, suddenly turned on . .  (substitute easy to wear off invisible black light reactive stuff you drew on yourself . .)
A printout layout chart, etc. is another cheap alternative.  Opening a jpg of the layout is a greener alternative.
On a more serious note, I think that's a solid idea.  Other than talking to a key manufacturer, I don't know of an existing alternative, though.
I had a thought, they make keyboard stickers, just get a pack and stick them on the sides.  You don't hit the sides, so they aren't going to wear.
« Last Edit: Mon, 10 May 2010, 22:27:47 by washuai »
⌨(home)Realforce 87U ⌨(backup) Filco Majestouch 104 Brown ⌨(backup)Cherry G80-8200LPDUS ⌨(work)Leopold FC200RT/AB
☛CST L-Trac-X ☛Logitech Wireless Optical Trackman ☛ Razer 3500 dpi ☛MS Explorer DeathAdder
Lay-a-bouts:  ⌨Full 109 Key Virtually Indestructable  Keyboard ⌨Compaq Radio Quack GYUR84SK
Wishlist: ⌨KBDmania Pure ⌨Déck 82 ice/frost/toxic/royal ⌨Ricercar spos G86-62410EUAGSA ☠ ✞⌨miniGuru(s) ☠
 ✐Intuos or Cintiq
