Author Topic: [IC] KAT Specimen: GB LIVE  (Read 68497 times)
Offline worldspawn
Re: [IC] KAT Specimen: GB LIVE
« Reply #100 on: Fri, 17 January 2020, 17:53:04 »
The set could use a 1.25 R3 tab and the extras kit would cover most 40% boards, also would be great for at least one of the novelties to be a 1.25 in purple.
I can make acrylic laser cut cases/plates PM for info
Offline JeniaBR
« Reply #101 on: Fri, 24 January 2020, 14:30:20 »
Hi,
This keycaps set looks awesome!
Can we get also a Mac layout option (cmd)? Or at least opposite colors for Alt and sys keys, so if I switch position between left Alt and left Sys it will still match the color in the diagonal?
Cheers!
Offline Rilow
« Reply #102 on: Sat, 08 February 2020, 06:11:05 »
How long does the GB run for?
Offline DrHigsby
  • The doctor is in.
« Reply #103 on: Sat, 08 February 2020, 19:55:16 »
Feb 23rd according to Kono
Offline chaoskills08
« Reply #104 on: Mon, 10 February 2020, 11:12:55 »
Heya there! Not super related to the keycap set, but if at all possible, I think a deskmat would make this look incredibly nice. Any thought about trying that out as well? Sorry if someone else suggested this. This set is just gorgeous and I want to build a whole setup around it.
« Last Edit: Mon, 10 February 2020, 11:14:27 by chaoskills08 »
Offline QQMBR
« Reply #105 on: Wed, 12 February 2020, 23:35:16 »
Thanks for the kind words. Deskmat definitely isn't coming with this GB, if anything, then later, but after talking to some vendors we didn't find it viable, although I wanted to do one at the start.
Offline QQMBR
« Reply #106 on: Wed, 12 February 2020, 23:37:17 »
Hi,
Cheers!
Can you suggest a concrete change? I don't want to make a color change that is bad for a large majority of users...
