Author Topic: can you please help me set up my cable?  (Read 3135 times)
Offline zebraman
« on: Mon, 10 May 2010, 20:50:59 »
I am completely technologically illiterate and cannot for the life of me, figure out how to connect my TV to my cable box.
I just had Comcast installed, but didn't have them set it up with the TV because I didn't yet have one. So now that I have a TV, I am trying to attach it to the cable box.
Attached are some ****ty webcam photos of the back of the cable box and the back of the TV.
Anyone willing to lend me a hand? I'm guessing I have all the necessary cords/cables already, or that everything I need came with the Comcast setup... right?
The TV is a 24 inch Vizio, and the cable box is Motorola.
Offline pfink
« Reply #1 on: Mon, 10 May 2010, 21:12:29 »
Quote from: zebraman;180856
Try this: run a coax cable from the wall to the coax connector on cable box labeled "Cable In" or "To Wall" or similar. Run the red/white/yellow composite cable from the red/white/yellow jacks on the cable box to the red/white/yellow jacks on the TV. Press the "Input Select" button on the TV remote and pick "Composite". Use the cable remote to change channels.
Offline skcheng
    • Tenafly Dentistry
« Reply #2 on: Mon, 10 May 2010, 21:20:24 »
Do you have HDMI inputs on your TV and cable box.  That is the easiest way to connect for HD TV.   One cable.   Great prices on cable over at monoprice.com
I can't tell from your pics whether there is an HDMI on your cable box?
Offline pfink
« Reply #3 on: Mon, 10 May 2010, 21:56:43 »
Quote from: skcheng;180860
It doesn't look like there's an HDMI out on that cable box. I only see coax and composite.
Offline itlnstln
« Reply #4 on: Tue, 11 May 2010, 07:38:14 »
Quote from: pfink;180868
I would seriously have Comcast give you an HD box.  HDMI is much easier to connect, and it has both sound and video.  I think you would be doing yourself a favor.  I would let you see my setup, but I don't want to contribute to another member's suicide.
