Author Topic: running floppies in 5150  (Read 7132 times)
Offline EverythingIBM
« on: Tue, 11 May 2010, 01:01:38 »
Okay, I must be bad with vintage technology. I got a few DOS games on 5" floppies and want to play them on my 5150. So I put one in, hit F3 for LOAD, and then type "A" for drive A (I'm guessing that's how it works). Then it clicks, waits for a minute, clicks again and I get a message that the "device timed out".
WHAT'S WRONG?!?!?! I need some IBMage.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #1 on: Tue, 11 May 2010, 02:03:40 »
some old games of that particular vintage will require you to boot with them inserted. they are entirely independent of your OS of choice.
best i can offer right there.
another possibility is your drive is dirty or faulty.
Edit: in retrospect, I see you're obviously letting it boot into BASIC in ROM.
If the game is the sort that the computer can boot from, boot the system with it in the drive. If it gives you no luck that way then you need to boot to an OS first - BASIC is not an OS. You'd need DOS something or other on another floppy, boot to it, then access the game in second drive (or swap for first if only equipped with one).
« Last Edit: Tue, 11 May 2010, 02:29:56 by kishy »
kishy.ca
Offline ch_123
« Reply #2 on: Tue, 11 May 2010, 03:47:06 »
Also, are the floppy disks the correct density for the drive?
Offline Rajagra
« Reply #3 on: Tue, 11 May 2010, 05:00:38 »
What are you booting into? If at the C:> prompt, type
A:
at the A:> prompt type the name of the game. Type
dir
to see what's there.
You kind of lost me at 'press F3 to load.' Is that an option presented when that model doesn't find a boot device, or is it some DOS shell?
(Sorry if I'm stating the obvious.)
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #4 on: Tue, 11 May 2010, 12:49:13 »
Quote from: ch_123;180904
VERY valid point.
Quote from: Rajagra;180914
A:
dir
5150 didn't include a hard drive by spec, so he'd need to boot a DOS floppy.
The fact that he is presented with the ability to press F3 to "load" means it found no suitable boot device and went to BASIC in ROM. IBM computers, I believe up to the Aptiva series, have Microsoft BASIC present in their ROM and will boot to it if they find no suitable OS on any other bootable media.
Accordingly, in order to have ANY DOS prompt, he's going to need to boot into DOS first. It is my belief that he doesn't have such a disk or he'd already have done it.
kishy.ca
Offline itlnstln
« Reply #5 on: Tue, 11 May 2010, 12:56:13 »
Ironically, 5150 is the California Welfare and Institution code for crazy people.  Ripster is on home confinement under this code.  That's why he can post here all day.
Offline bhtooefr
    • bhtooefr.org
« Reply #6 on: Tue, 11 May 2010, 14:00:41 »
I know the PS/1, which predated the Aptiva, didn't have BASIC in ROM, had to use BASICA.COM to get BASIC.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #7 on: Tue, 11 May 2010, 14:05:23 »
Quote from: bhtooefr;181146
PS/2s definitely do have it.
I believe after the PS/1 was the Aptiva and I don't think Aptivas had it...I also know the 300PL didn't have it, so maybe PS/1 was the c-c-c-c-combo breaker.
kishy.ca
Offline bhtooefr
    • bhtooefr.org
« Reply #8 on: Tue, 11 May 2010, 14:13:55 »
It could've also been part-way through the PS/2's run. I know the PS/2 I used was a very early 386-based one, but maybe a 286 PS/1 could've had it.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #9 on: Tue, 11 May 2010, 14:29:38 »
Quote from: bhtooefr;181157
My PS/2 8530-E01 (that's a Model 30 286) has BASIC in ROM.
It's been a while since I fired it up with no bootable media, but I believe my 8556-045 (Model 56 SX) also has it.
kishy.ca
Offline bhtooefr
    • bhtooefr.org
« Reply #10 on: Tue, 11 May 2010, 14:46:49 »
Er, I meant PS/1 everywhere I said PS/2, but my comments might still apply to the PS/2.
Offline ricercar
  • mostly abides
« Reply #11 on: Tue, 11 May 2010, 15:30:30 »
Quote from: itlnstln;181084
5150 is the California Welfare and Institution code for crazy people.  Ripster is ...
That's me. ripster's not a Californian, at least not the last time he sent me a letter bomb.
Offline ricercar
  • mostly abides
« Reply #12 on: Tue, 11 May 2010, 16:34:44 »
Damn. I bet you're going to tell me the Credit Fairy isn't real either.
Offline itlnstln
« Reply #13 on: Tue, 11 May 2010, 16:35:47 »
Greece is finding that out the hard way.
Offline ricercar
  • mostly abides
« Reply #14 on: Tue, 11 May 2010, 16:55:13 »
Quote from: ripster;181276
Credit Fairy?
If you were really Californian, you'd know about the Credit Fairy commercials. Or wait. Maybe that''s only if you're from Hulu.
Offline ch_123
« Reply #15 on: Tue, 11 May 2010, 17:20:29 »
Quote from: kishy;181148
IBM was still putting BASIC ROMs into PS/2s? You'd think they'd have moved on by that stage to something more useful....
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #16 on: Tue, 11 May 2010, 17:23:13 »
Quote from: ch_123;181302
Something to do with a license agreement with MS.
kishy.ca
« Reply #17 on: Tue, 11 May 2010, 17:53:18 »
Yeah, before I get ahead of myself I'll need some old 5" DOS floppies to run the game.
The drive doesn't look dusty to me, the computer was kept in dustless condition.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #18 on: Tue, 11 May 2010, 21:40:14 »
Quote from: EverythingIBM;181316
F3 for load suggests you're at the Casette BASIC "Ok", not the DOS "A>"
http://www.freedos.org/ will help.
Overton130, Box Pale Blues.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #19 on: Tue, 11 May 2010, 21:54:35 »
FreeDOS won't help if he doesn't have the ability to actually write an appropriate disk (which is likely to be a 360k, and if written in a high density drive will be unreliable at best)
kishy.ca
« Reply #20 on: Tue, 11 May 2010, 22:05:04 »
Quote from: kishy;181378
I do have a 5" floppy drive that fits into (moreso) modern computers, but it's some weird port which I've never seen before.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #21 on: Tue, 11 May 2010, 22:06:37 »
Quote from: EverythingIBM;181381
I almost guarantee it's high density. Useless for getting stuff onto disks if you want them readable in a low density drive, even if using low density media.
It's a card edge connector and is nothing unusual, it's the same connector that's been present on the majority of floppy cables forever in addition to the pin connectors.
kishy.ca
Offline ricercar
  • mostly abides
« Reply #22 on: Wed, 12 May 2010, 01:15:31 »
Quote from: kishy;181382
The 5-1/4 floppy card edge connector stopped general availability with the Pentium (1). I haven't seen a cable for those at retail for 15 years.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #23 on: Wed, 12 May 2010, 01:47:19 »
Quote from: ricercar;181401
Perhaps I've got a stockpile of something useful to Mr. OP then.
kishy.ca
Offline ch_123
« Reply #24 on: Wed, 12 May 2010, 04:02:10 »
eBay and skips are your friend.
I think I remember reading that there was some issues with 360K floppies in 1.2MB drives. Can anyone confirm?
Offline Rajagra
« Reply #25 on: Wed, 12 May 2010, 04:24:42 »
Works fine as long as you start with an unused disk - i.e. *never* formatted before.
Offline bhtooefr
    • bhtooefr.org
« Reply #26 on: Wed, 12 May 2010, 04:47:41 »
The issue is that 5.25" High Density drives have trouble writing Standard Density/Double Density disks correctly, so that 360k and smaller drives can read them.
SD and DD have different magnetic coercivity.
Offline Rajagra
« Reply #27 on: Wed, 12 May 2010, 06:18:13 »
I thought the problem was much simpler. The tracks on 1.2MB disks are half the width of those on a 360K one, as are the active parts of the read/write/erase heads.
A high density drive can effectively only write to half of a track width on a low density disk. That leaves half of the track holding old data, making it hard to read reliably.
If you start with a fresh, never formatted disk, the high density drive can use it properly up until the point a low density drive writes something to it.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #28 on: Wed, 12 May 2010, 09:41:54 »
Quote from: Rajagra;181415
I was referring to the track width thing also.
Even never-before-formatted media can give problems simply because the high density drive is going to write slightly "off" from where the low density drive may expect. No way to know if it'll work without just doing it to see.
kishy.ca
