Author Topic: 71-keys keyboard or F-row-less TKL  (Read 3570 times)
Offline phinix
« on: Mon, 07 January 2019, 13:23:23 »
I only found this 71-key keyboard called Drevo Calibur.
I would love to see onelike this but good quality one - do they exist? Apart from that Calibur one...
Offline pixelpusher
Re: 71-keys keyboard or F-row-less TKL
« Reply #1 on: Mon, 07 January 2019, 13:48:10 »
Not exactly what you are looking for but similar.
https://geekhack.org/index.php?topic=98543.0
Offline HotRoderX
« Reply #2 on: Mon, 07 January 2019, 13:51:12 »
Define good quality? I mean heard nice things about Drevo. I read its a great budget board a lot of bang for your buck.
I know it uses Outemu switches which haven't heard anything bad or good about. I would assume over all there a decent switch that just doesn't catch to much flack.
As far as the wireless function of the board I would consider that worthless the fact its bristling with LED's means the battery most likely wouldn't last for crap.
Overall I wouldn't call a Drevo a low quality board, anymore then I would a poker 3.
Offline phinix
« Reply #3 on: Fri, 11 January 2019, 16:14:31 »
I would love to see this kind of layout and other case, like a bit more around keys, something like CA66, or DORO67...
