Author Topic: 96 keyboard layout mechanical CAD files  (Read 4144 times)
Offline spectrumz
« on: Wed, 09 January 2019, 09:29:52 »
Hi. I'm new to the custom mechanical keyboard world. I'm interested in machining my own metal case for a 96 keyboard. I have access to a CNC machine at my university and cheap stock materials. I've been trying to find some online CAD files for keyboards but can't seem to find any. If not for CAD, are there any technical drawings out there? Thanks in advance!
Offline Lanrefni
Re: 96 keyboard layout mechanical CAD files
« Reply #1 on: Wed, 09 January 2019, 09:59:57 »
You can use http://www.keyboard-layout-editor.com/#/  to create your layout,then copy the Raw Data over to http://builder.swillkb.com/ ,that will allow you to create a basic sandwich case from the files it creates.
