Author Topic: Custom Keyboard Concept  (Read 13889 times)
Offline Ruskie
« on: Sat, 12 January 2019, 20:55:36 »
To those of you who are experienced with ergo layouts, would something like a split ortholinear that uses standard keycap sizes be useful? I am thinking of trying something like this on my laser cutter at school!
Ive got myself a beefy boi
-Alf F62PE
-PCB Mount ZealV2 67g
-GMK KA1953 "OG Classic Retro"
8 pounds of clack
Offline macroxue
    • Darknight: DIY 60% Split Keyboard
Re: Custom Keyboard Concept
« Reply #1 on: Sun, 13 January 2019, 19:53:44 »
The left side seems OK but the right side may have a few keys that are hard to reach, like backspace and '='.  One way to see if you like the layout is to print it out on a piece of paper and type on it.
[Darknight: DIY 60% Split Keyboard](https://github.com/macroxue/keyboard-diy)
Offline Nerd
  • Nerd (Aka Alex) Aka Garbage. Sister: @sintpinty
    • My Youtube channel!
« Reply #2 on: Tue, 26 March 2019, 10:10:59 »
I like it. However, i find the space would be awkward in the middle.
"The world's nerdiest nerd that loves Youtube."
Consider subscribing to my channel, TanookiAlex. That would be greatly appreciated, thank you! Link is: Youtube.com/c/tanookialex.
                *  Subscriber Goal - 735/1000 *
Offline blawb
« Reply #3 on: Tue, 26 March 2019, 14:11:45 »
What "standard" size keycaps are the spaces? Usually people use shifts as spaces for split spacebars, but you're using the shifts as shifts. I'm not sure if I like the look of the layout, but I do really like the idea of being able to easily find keycaps for split boards.
i hate wet socks
Offline geekabit
    • geekabit.nl
« Reply #4 on: Wed, 10 April 2019, 04:44:48 »
If you are ditching the F-keys and arrow keys, do you have a plan how you would replace those? On my design I have added a 'Fn' key that shifts to a second layer that has all those keys.
Offline Legonut
« Reply #5 on: Sat, 13 July 2019, 00:47:24 »
I'd recommend using a standard spacebar size like 2u, 2.25u, or 2.75u
Offline Myteethfeelweird
« Reply #6 on: Mon, 13 January 2020, 22:53:12 »
This concept reminds me of the Ogre, on r/mechanicalkeyboards
It's really cool to see normal layout caps on an ortho board
