Author Topic: [GB] Alpha 28 PCB and kits (closed, shipped, extras available)  (Read 28798 times)
Offline worldspawn
« on: Fri, 18 January 2019, 17:22:57 »
Current status: closed, shipped
I have some PCBs and case layers left (clear plate, frosted bottom) out of the hardware and pro micros.
remaining PCBs: $10
plate/bottom set: $11 https://www.etsy.com/listing/684507874/alpha28-acrylic-case-set
PCB with case set: $20
PM me for interest
US shipping $8/order priority $3 first class
international first class $15 (for one full kit or less)
This thread is for tracking the progress of the group buy initiated from an interest check in the 40% discord/mechmarket subreddit (feel free to join).
The board (kit does not include switches or caps)
The PCB (this group buy will be for PCBs with gold plating on the solder pads!)
Case color options
Group Buy form here
https://docs.google.com/forms/d/e/1FAIpQLSfki00GY4T7XDOvfl2IjdxVbLkaXDdKtx3JSYWzCbZawp3_Rw/viewform?usp=sf_link
Timeline
GB closes 1/28/19
Invoices will go out upon end of GB period, payment due by Feb 2nd
kits would ship approximately 3 weeks after GB ends (we hit Chinese new year, PCB factory is closed till Feb 11th) I'll post updates here as it progresses
The Alpha 28 is QMK compatible! (And for those ordering a kit, the Pro Micro will be pre-flashed with this layout: https://github.com/qmk/qmk_firmware/tree/master/keyboards/alpha/keymaps/vderm
PCB and case are MX(plate or PCB mount) and alps compatible.
Buy is for: PCB, case, or kit for Alpha 28 keyboard with LED underglow (kit does not include switches or keycaps)
Kit ($30) includes:
PCB
pro micro (ready to use, no programming necessary)
2 piece case (plate and bottom)
screws and standoffs
diodes
1x 2u stabilizer
RGB LED strip for underglow
Other options:
Just a Case ($10): 2 pieces of acrylic (plate and case bottom)
Just a PCB ($10): single bare board, black soldermask with white silk screen and gold plated pads
shipping for up to 3 kits or 8 PCBs (if you're getting more than that, I will provide a separate estimate)
Priority within the US $8
First class to Canada $10, rest of the world $15
Priority to Canada $25, rest of the world $35
details and assembly instructions here: https://github.com/PyrooL/Alpha
original design by /u/pyrocrastinator (PyroL) reproduced with permission under MIT license
« Last Edit: Tue, 14 May 2019, 23:42:11 by worldspawn »
I can make acrylic laser cut cases/plates PM for info
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] Alpha 28 PCB and kits
« Reply #1 on: Fri, 18 January 2019, 17:42:50 »
Approved
Offline MikeTheTiger
« Reply #2 on: Fri, 18 January 2019, 17:54:01 »
Congrats!!
"all the numbers or none of them cmon man" -Kokaloo
Offline PyroL
« Reply #3 on: Fri, 18 January 2019, 23:09:08 »
blessed keyboard
first person to build this with brown alps gets a meme from pyro, custom delivered to their discord inbox
Offline worldspawn
« Reply #4 on: Sat, 19 January 2019, 00:21:24 »
I'm seriously tempted to make a hotswap Alps version with Mill-Max 7305s  :D
« Last Edit: Mon, 21 January 2019, 09:34:40 by worldspawn »
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #5 on: Sat, 19 January 2019, 02:17:40 »
Hotswap alps? I might have to steal that idea.
Do you have any photos of the translucent gray color?
Offline SargentRedbeard
« Reply #6 on: Sat, 19 January 2019, 17:28:01 »
Super excited to be apart of this GB!
Offline worldspawn
« Reply #7 on: Sat, 19 January 2019, 22:03:54 »
Here's the case color options
« Last Edit: Sat, 19 January 2019, 22:06:59 by worldspawn »
« Reply #8 on: Sun, 20 January 2019, 07:24:29 »
Need a banana in the picture for size reference.
Offline worldspawn
« Reply #9 on: Sun, 20 January 2019, 11:19:47 »
Emails have gone out to those who replied to the initial Interest Check, thanks guys!  The GB is open through the 28th, if you want to get in, please fill out the form above.
« Last Edit: Mon, 21 January 2019, 09:35:27 by worldspawn »
Offline PyroL
« Reply #10 on: Mon, 21 January 2019, 05:26:58 »
Ask and ye shall receive
211085-0
Edit: oh hey how do I rotate images on Geekhack?
Offline worldspawn
« Reply #11 on: Tue, 22 January 2019, 11:19:00 »
I found some beefier pro micros with through-hole mounted micro-USB ports that should be more robust than the more common pad-soldered ports that most pro micros use.  We've got enough orders, this will not result in an increase in price :D
[ignore this]
« Last Edit: Sun, 27 January 2019, 21:49:36 by worldspawn »
Offline PyroL
« Reply #12 on: Wed, 23 January 2019, 01:58:15 »
Those Pro Micros won't fit :-X
Too wide, gotta use standard Pro Micro width
Offline worldspawn
« Reply #13 on: Wed, 23 January 2019, 08:41:12 »
I was wondering about that, it's hard to tell from the photos and the size wasn't listed. Thanks for the info.
Offline TunnaTown
« Reply #14 on: Wed, 23 January 2019, 12:27:48 »
Yeah, I have a few of those clones and while from the technical perspective they are identical to the original one, they are considerably wider.
A tip for selecting a clone: choose one with the smaller cpu that's rotated by 45 degrees. Those are usually the same width as the original
« Last Edit: Wed, 23 January 2019, 12:30:52 by TunnaTown »
Offline worldspawn
« Reply #15 on: Wed, 23 January 2019, 13:07:00 »
Yeah, I know which ones are guaranteed to fit, I tried to get size info from the seller, but they said they didn't know, so back to the standard :(
Offline William_S_Jones
  • Best Prime Ever!!!
« Reply #16 on: Wed, 23 January 2019, 21:18:12 »
I’m glad I joined this GB from ic form you had on reddit, Now that I came across this here. I’m following it’s progress. Great job, OP!!
Offline worldspawn
Re: [GB] Alpha 28 PCB and kits (OPEN FOR ORDERS TILL THE 28TH)
« Reply #17 on: Sun, 27 January 2019, 15:39:51 »
GB is closing in 3 hours! LAST CALL
Offline worldspawn
Re: [GB] Alpha 28 PCB and kits (closed, invoices going out)
« Reply #18 on: Sun, 27 January 2019, 18:02:04 »
Thanks for the orders everyone, invoices are going out now, ping me if you don't get one in the next 24 hours.
Offline krey
« Reply #19 on: Sun, 27 January 2019, 20:03:37 »
paid!
now i wait.  ;D
Kepler FC65 | 7v | Think6.5 v1 | Maja | G60 | TX75v2 | Fjell | Klippe x2 | Acrylic Tofu | CA66 | Norbaforce
Offline worldspawn
« Reply #20 on: Sun, 27 January 2019, 21:18:54 »
Thanks to those who paid quick! Some of you guys are fast :D I've gone ahead and placed the slowest part of the orders, the PCB, and I think I've managed to get it in before the Chinese New Year celebration, so that's good news! Updates will be posted here as the parts come in.
If you have not received an invoice, please PM me!
Offline dailyskeptic
Re: [GB] Alpha 28 PCB and kits (closed, invoices sent)
« Reply #21 on: Sun, 27 January 2019, 21:46:40 »
Thanks!  ;D
« Reply #22 on: Mon, 28 January 2019, 07:42:55 »
Paid
Offline worldspawn
« Reply #23 on: Wed, 30 January 2019, 23:56:18 »
Had a few people drop out after the GB closed, so there's a few extra kits avaialble, if you're interested, PM me with what you would like and I'll invoice you.
Offline lun0r
« Reply #24 on: Thu, 31 January 2019, 03:01:12 »
Just recently joined this hobby and am very grateful to be part of this as my first GB :)
Looking forward to this lil`fella
Offline worldspawn
« Reply #25 on: Thu, 31 January 2019, 19:22:11 »
Initial boards are in, looking good, matte black and gold pads
Also a ton of pro micros and RGB LEDs
« Reply #26 on: Fri, 01 February 2019, 14:21:18 »
 ;D :thumb:
Offline worldspawn
« Reply #27 on: Fri, 01 February 2019, 18:23:33 »
Getting the RGB going
With the frosted bottom
Here's the keymap I'm putting on the pro micros
Essentially the vderm layout, but added the RGB control
« Last Edit: Fri, 01 February 2019, 19:20:38 by worldspawn »
Offline Capsy
« Reply #28 on: Sat, 02 February 2019, 02:08:10 »
Yay looks wonderful. Waiting for my kit to arrive  :D
Offline worldspawn
« Reply #29 on: Sun, 03 February 2019, 11:12:57 »
GB is closed, parts are all ordered. Most of the parts will be in probably end of this week, but a couple got caught in Chinese New year closures and won't go out till after the 11th.
I'm targeting shipping out orders the week of Feb. 25 pending everything getting in on time.
« Last Edit: Sun, 03 February 2019, 13:46:27 by worldspawn »
Offline Capsy
« Reply #30 on: Tue, 05 February 2019, 12:39:35 »
Hey,
What's the best way to reach you? I will be moving houses on Feb 25th so will need an address change.
I know this is an inconvenience but I did not want to miss out on the board. I don't have my new address yet but I will get it to you as soon as possible.
Offline worldspawn
Re: [GB] Alpha 28 PCB and kits (closed, parts ordered)
« Reply #31 on: Tue, 05 February 2019, 12:41:31 »
PM or email, my email should have been on the invoice.  I'll also PM you my info directly on here.
Offline Nomeon
« Reply #32 on: Fri, 22 February 2019, 15:46:35 »
Hi there! Do you have any status updates? Kind regards!
Offline worldspawn
« Reply #33 on: Fri, 22 February 2019, 17:12:10 »
Yes!
I received the last of the parts I was waiting on today, the screws.
I'm nearly done cutting out the cases, just the clear plates to go.  Plan to start shipping this week.
« Reply #34 on: Sat, 23 February 2019, 21:42:22 »
Fantastic - can't wait  ;D :thumb:
Offline mrnagrom
« Reply #35 on: Mon, 25 February 2019, 07:58:07 »
I’m pretty stoked. Can’t wait for the “shipped” update
Offline worldspawn
« Reply #36 on: Wed, 27 February 2019, 22:03:22 »
Shipping started this afternoon, about 1/3 of orders are going out today, the rest will follow over the next couple days.
Offline Capsy
Re: [GB] Alpha 28 PCB and kits (closed, shipping)
« Reply #37 on: Wed, 27 February 2019, 23:30:17 »
Got the tracking number. Can't wait. Thank you for running a great GB :)
Offline mrnagrom
« Reply #38 on: Sat, 02 March 2019, 16:26:21 »
Hell yah. Got mine today. Hopefully i’ll get to put it together this week
Offline worldspawn
« Reply #39 on: Sat, 02 March 2019, 20:35:40 »
Quick update, most of the domestic orders have gone out, a couple day delay in the last few domestic and international orders due to paypal transferring funds super slowly.  The rest of the orders should be going out early this coming week.  Thanks again everyone!
Offline worldspawn
« Reply #40 on: Tue, 05 March 2019, 22:32:26 »
All orders are shipped. Let me know if you didn't get a shipping confirmation from PayPal.
Offline Capsy
« Reply #41 on: Tue, 05 March 2019, 22:33:47 »
Got it. Can't wait to build it :)
Offline Nomeon
Re: [GB] Alpha 28 PCB and kits (closed, shipped, extras available)
« Reply #42 on: Mon, 11 March 2019, 17:17:56 »
Hi there! I've received a tracking code, but it still says PRE-Shipment, March 5. Any clue on when it's going to be send out, or some more info? Thanks in advance!
Offline worldspawn
« Reply #43 on: Mon, 11 March 2019, 17:55:52 »
PM me your email you used for the payment and I can check on it.
Offline lun0r
« Reply #44 on: Wed, 13 March 2019, 10:30:01 »
Arrived today in Germany :) looking good and will be build next , thanks for the fast GB!
Offline worldspawn
« Reply #45 on: Wed, 13 March 2019, 10:41:34 »
Great, over 1/4 of the orders were international, and this is the first time I've sent a bunch of international packages, glad to hear they're making it to their destinations!
Offline Nomeon
« Reply #46 on: Thu, 28 March 2019, 13:00:14 »
Hi there! Quick update, still nothing arrived. USPS tracking gave me no updates after 18 march.... Could you message me private or something to check for me? It's almost taking a month now to the Netherlands, so something is wrong. Please help!
Offline worldspawn
« Reply #47 on: Thu, 28 March 2019, 13:04:04 »
PMd you, we'll see what we can find :)
Offline mrvectrex
« Reply #48 on: Sun, 19 May 2019, 11:43:43 »
Hi all, I'm new here so please forgive me dropping in from nowhere. I absolutely LOVE the look of this keyboard and clearly have missed the GB, so was wondering if there is any way to get hold of a kit now - I am in the UK, if that is any help.
cheers
Russell
Offline Nigolski
« Reply #49 on: Sun, 19 May 2019, 11:46:31 »
cheers
Russell
not sure if they are still available but check the first post for the etsy links
