Author Topic: [IC] TYL 4mm plate in Brass and PC.(In stock sale tonight!2/11/2020)  (Read 49522 times)
Offline voight-kampff
Re: [IC] TYL 4mm Brass Plate, Time to Enhance Your 60% Keyboard(sample updated)
« Reply #100 on: Thu, 28 February 2019, 07:06:34 »
can't wait for the GB, I am in
Offline bobdenard
« Reply #101 on: Thu, 28 February 2019, 08:21:25 »
Is the matte sandblasted finish more prone to tarnish over time in regards to pvd finish?
Offline oli
« Reply #102 on: Thu, 28 February 2019, 08:23:37 »
Sample is out! https://uploads.tapatalk-cdn.com/20190227/31f69592143c711899a78cc8144277b6.jpg
Matte sandblast finished: https://uploads.tapatalk-cdn.com/20190227/15a26e34dbfd29304b6c0def45714b8b.jpg
Engraved logo: https://uploads.tapatalk-cdn.com/20190227/bb6ebffc71ed91d5c4bd0e62941c4acd.jpg
从我的 iPhone 发送,使用 Tapatalk
No chance for ISO?
Will do separate layouts, I don’t like universal plate. This is just sample layout.
Perfect! That was exactly what I was hoping for! I wasn't advocating universal plates, I just couldn't find anything related to ISO in the thread. Specific plates for specific layouts sounds awesome.
Count me in.
Offline Justin_aka_OsP_SSJ4
  • Chellow... it's me...
    • My Twitch
« Reply #103 on: Thu, 28 February 2019, 19:15:03 »
Louis did the factory give you indication of how layout options will effect the cost?
I read on discord the first price drop is MOQ of 50. But is that a single layout? or are they factoring in that you will request a number of fixed layout plates?
DC60 w/ DZ60 PCB & Steel plate w/ 3mm neoprene foam - 68g Chellows Lubed w/ 3204 - Find me on twitch/twitter Osprey_SSJ4
Offline Poblopuablo
Is there a plan to make a 65% (like tada compatible layout)? Just wondering :D
Offline lbaron
I'll definitely be picking on up. Would prefer either of the following layouts:
WK, split R-shift,stepped/normal caps lock
Ansi with split R-shift, stepped/normal caps lock
Offline ilouis_07
  • Never Forget Your Origin
    • ILUMKB
4mm brass plate weight
VS
1.5mm alum plate weight
Offline bobdenard
Stop teasing! When’s the GB?
Offline pixelpusher
They look fantastic.  I really need one for my HS60 boards.  Would be the perfect combo.
Offline leece3
« Reply #109 on: Sun, 10 March 2019, 16:55:14 »
I'd really be in on this. I'm specifically looking for split backspace and split right shift, with a 1.5, 1, 1.5, 7, 1.5, 1, 1.5 bottom row.
Exactly what I want. With brass. 4.5 mm would be also acceptable;). Cheers.
Offline cucgach
dying for ISO layout support :(
Current: Filco TKL Majestouch | TX60 antique brass | NIU40 silver | H360 burgundy | tr.mk wooden 60 | Imperial Hue 60 | Tofu 65 silver | Tofu WKL navy | Gergo Kit: black PCB | Space65 gray/silver | VN66 Black
Future: none
Past: TinaC HHKB gray | TX84Se titan gray | Leopold 660M white | GSX96 R2 purple | Rama M60-A lake | 0.01 Z70 silver | E7-V1 MAO | Rama M6-A | TMO50 green/poly | HB85 black/gray | TX108se titan gray | Typewriter68 ceramic white | Think6.5 frost poly
Offline Aerizu
  • Professional Lurker
Ansi, split backspace, split R-shift, stepped/normal caps lock up
  :cool: :cool: :cool:
Offline oldcat
  • 65% is Life
ISO Enter seems easy to add :) Also need split left shift I guess?
Offline cucgach
to be honest, i might be the only one use this layout
214900-0
Future: none
Offline oldcat
  • 65% is Life
More people than you think :) I have seen a friend who uses this layout.
Offline TheMastermind
Any updates on this IC?
Offline ilouis_07
    • ILUMKB
I did some mistakes on the prototype. The factory needs to redo a new one. it may take a while.
Offline pixelpusher
All good.  This is a very nice product that I plan to buy more than 1 of, so I'm down for having it perfecto!
Offline Rykno
I'm patiently waiting to buy 2 ANSI & WKL/HHKB plates.
Offline GigaFlop
Will you be able to release the CAD file after the GB?
Oh god why did my wallet get so thin
Offline nasp
This would be nice although it is possible to make your own with KLE and a website. Sorry. I forget the address
Offline GigaFlop
I know the site you're talking about - I'm more interested in the CAD that has the cutouts for the switches to lock into place. SwillKB doesn't provide that option, afaik.
Offline ilouis_07
    • ILUMKB
nope, sorry
when is the GB planned?
Offline HPE1000
  • Keycap Paparazzo
Fingers crossed WKL PC plate gets made  :)
Offline ilouis_07
    • ILUMKB
Probably GB will be April or May. I need to wait my second prototype, assemble it and do sound typing.
Offline Uryftw
I wish that I could get one for my custom layout in my DZ60 PCB :(
Are the layouts fixed now, or will there be maybe a split spacebar?
Not a deal breaker for me, I will a few of this plates anyway, but a 3u 3u spoil spacebar would be great
Offline ilouis_07
    • ILUMKB
updates: Doing Prototype V2, 4mm PC in for this round.
Offline DetectiveNio
Hghh NUT. Sound video inc please :-* :-*
Offline Wojtko
Any chance of split spacebar?
Offline realxmlforce
Looking for split space support as well! Probably too niche though
Gesendet von meinem Nokia 7 plus mit Tapatalk
Offline HPE1000
  • Keycap Paparazzo
The second you start trying to support a bunch of layouts with a plate like this, it starts ruining the design. Look at sprits 5mm acrylic plates, and what supporting split spacebars and everything does to that area of the plate.
You are right. It would have to be a plate on its own with fixed split space layout to make sense...and the demand for that is way too low unfortunately.
Offline ramnes
  • T fou, mec?
Interested for an ISO one. Do you think you could cut and sell some foam to put between the PCB and the plate also?
Offline Ashardalon
  • Ashkeebs
    • Ashkeebs Lubing Service & Shop
Now we just need one for 65% boards; love me some t h i c c brass plates.
Offline Darknight00z
not sure if it was answered already, but yes. I never go sandblast finish on brass anymore, unless you like the tarnish look.
Offline the_ambyguous
  • there's a fine line between click and clack
in for one, rose gold preferably, whatever shiny is. im guessing no alps support?
Magnavox Typewriter | AEK64 | 658-4081 | Leading Edge 3501 | Omnikey Orange | 197Stotle | MPC2000
Offline Von Steve
Any way to get a satin or matte type finish?
Offline dyrdevil
+1 for 4mm PC
Offline equalunique
Yooooo
Make one for the Boardwalk PCB >:D
Offline fromjuanm
Is this plate designed to only be used with specific style keycaps? I notice on my 60% board that my keycaps bottom out exactly on top of the plate. With the switches being sunk in about half way of the 4mm thick plate it seems my keycaps would have around 2mm less travel before bottoming out. My switches have a travel distance of 3.6mm so it seems this would drastically change the feel. Maybe I am missing something.
Offline ilouis_07
    • ILUMKB
est timeframe: end of May or early of June, we can get our new prototype. The factory is quite busy with Volcano660 manufacturing works.
Offline dav1k
Very interested in this ballin' plate. ANSI, Step/Normal CapsLock, Split R-Shift.
Great work mate!
Offline HPE1000
  • Keycap Paparazzo
Keycaps will never touch the plate no matter what plate is being used. The thicker the plate, the further it (the plate) goes down towards the PCB, filling in the gap between the switch and the PCB.
Offline Kaktus
+1 for ISO Support
Offline Uryftw
I'd take two.
Offline equalunique
I'm interested in this 4mm brass plate so I can pair it with the 4mm brass plates that come with the Sol 2. Did the GB happen already? Hoping there is a chance to get one. :D
Offline ilouis_07
    • ILUMKB
Finally, we finished our second round 4mm Brass and PC version prototype. It is otw to me.
Offline ilouis_07
    • ILUMKB
Potato picture for brass 4mmplate before polish, Sandblast and coating works.
