Author Topic: [IC] TYL 4mm plate in Brass and PC.(In stock sale tonight!2/11/2020)  (Read 49524 times)
Offline enrique.aliaga
Re: [IC] TYL 4mm Brass Plate, Time to Enhance Your 60% Keyboard
« Reply #50 on: Fri, 25 January 2019, 07:50:11 »
BTW, how is a 4mm plate different from a 1.5mm one? Particularly in brass. How are the acoustics and/or feel different?
Offline regionfree
« Reply #51 on: Fri, 25 January 2019, 08:14:48 »
they sound crisper, in the sense that the tap sound on the plate doesn't linger, and goes away quicker. and a bit deeper. really sounds good.
Offline voight-kampff
« Reply #52 on: Fri, 25 January 2019, 08:37:46 »
I am in
Offline tectonicplate
« Reply #53 on: Fri, 25 January 2019, 14:08:07 »
+1 for 2nd layout option… arrow keys and split backspace.
Offline odd
« Reply #54 on: Fri, 25 January 2019, 15:41:55 »
Question, why 4mm and not 5mm? none the rest count me in for 2. 1poly,1brass
Offline TheAutoManCan
« Reply #55 on: Fri, 25 January 2019, 18:41:29 »
That ANSI split RShift/Backspace plate is perf +1
Offline ZyBeR
« Reply #56 on: Sat, 26 January 2019, 05:50:41 »
Yeah - seams like 5mm is doable (Zephyr for example is using that).
« Reply #57 on: Sat, 26 January 2019, 12:46:44 »
5mm worked with the Zephyr since the PCB was designed with that in mind. A 5mm plate used with a common 60% PCB like the DZ60 could result in issues since, depending on tolerances and layout, the plate could make contact with various pads. But I imagine there are workarounds to prevent something like that being an issue.
Offline RETURNISO
  • I do get excited about keyboard stuff..
« Reply #58 on: Sat, 26 January 2019, 13:21:20 »
I think the Zephyr "only" was 4.5mm it's gonna be dangerous making the plate 5mm... It would be nice with 1mm tolerance on dif switches and pcbs
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #59 on: Sat, 26 January 2019, 19:11:23 »
Also the typing feel will be quite different. The top-out clack will be very firm, and the bottom-out feel will be very hard.
Offline Munky
« Reply #60 on: Sun, 27 January 2019, 12:07:06 »
I guess it's time to sign up for a Geekhack account.
Count me in on this THICC plate!
and +1 for the layout with arrow keys.
https://i.imgur.com/8XEhCSM.png
Offline Sic_Alpha
« Reply #61 on: Sun, 27 January 2019, 21:03:53 »
Concerning comments on DZ60 above.  Will this not work with a DZ60?  I would be using it with a V 3.0 of a DZ 60.  Thanks
Offline nu_types
  • Formerly Iredeus
« Reply #62 on: Sun, 27 January 2019, 21:44:54 »
Last one is best. I prefer full sized backspace and WKL.
Offline kidpid
« Reply #63 on: Tue, 29 January 2019, 13:15:28 »
These are the layouts i am working on so far.
https://imgur.com/a/fILmUJs
any suggestions so far?
Would #4 also cover standard RShift?
Offline ilouis_07
  • Never Forget Your Origin
    • ILUMKB
« Reply #64 on: Tue, 29 January 2019, 19:59:52 »
nope, but i can add one more plate for 2.75u standard Rshift.
Offline kidpid
« Reply #65 on: Tue, 29 January 2019, 20:56:09 »
Cool, I'd be interested in a rose gold one with that layout.
Offline Agpatel
« Reply #66 on: Tue, 29 January 2019, 20:58:23 »
Interested as well
Offline Sic_Alpha
« Reply #67 on: Tue, 29 January 2019, 21:59:51 »
Interested in the first plate shown on the imgur album "64 keys layout, included arrow keys,stepped/normal caps lock" for the new DZ60RGB, as long as plate isn't an issue with that PCB.
Offline CrazyNun
« Reply #68 on: Thu, 31 January 2019, 10:44:55 »
XXXtra Interested
Offline slow_wave
« Reply #69 on: Sat, 02 February 2019, 16:15:30 »
Just made an account to express how interested I am in this. I'd consider buying two just to help with MOQ. 60% ansi pok3r layout in either classic brass or rose gold would be perfect for me, but I'd be thrilled with whatever gets made.
Offline Justin_aka_OsP_SSJ4
  • Chellow... it's me...
    • My Twitch
« Reply #70 on: Thu, 14 February 2019, 19:00:43 »
Louis update plez XD XD
DC60 w/ DZ60 PCB & Steel plate w/ 3mm neoprene foam - 68g Chellows Lubed w/ 3204 - Find me on twitch/twitter Osprey_SSJ4
Offline Darknight00z
« Reply #71 on: Fri, 15 February 2019, 12:29:47 »
During long working/ typing sessions. I am feeling a bit of fatigue with my current boards with 1.5mm brass plate. 63.5g springs, so not too heavy. I was wondering will 4mm brass plate feel different?
I am starting to see the appeal of half plate, but I'm not too comfortable with exposed pcb. Will try out the poly and carbon fibre plates I have hidden somewhere.
Offline aroostercat
« Reply #72 on: Fri, 15 February 2019, 15:00:43 »
instant buy for me!
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #73 on: Fri, 15 February 2019, 15:12:27 »
It's not your keyboard ;)
Offline puddingfarmer
« Reply #74 on: Sat, 16 February 2019, 01:09:44 »
Any timeline on this? Interested for sure!
Offline OracleKev
« Reply #75 on: Sat, 16 February 2019, 06:35:12 »
Interested if price is reasonable.
Offline gnunin
« Reply #76 on: Sat, 16 February 2019, 06:52:41 »
Might be interested.
Offline kuchann
« Reply #77 on: Sat, 16 February 2019, 07:00:04 »
yes interested! would go for one right away
Offline CrazyNun
« Reply #78 on: Sat, 16 February 2019, 07:15:31 »
Someone earlier on this thread mentioned this plate would be great with a sandwiched case - maybe something like the acrylic cases Qlavier does.  I second that opinion.
    • My Twitch
« Reply #79 on: Sun, 17 February 2019, 17:10:51 »
it's meant for tray mount style cases. So wouldnt work with sandwich style would it?
Offline Silyl Ether
« Reply #80 on: Tue, 19 February 2019, 04:04:54 »
This plate is really interesting. I vote to "WK, split backspace, split R-shift, stepped/normal caps lock" :thumb:
Offline ZyBeR
« Reply #81 on: Tue, 19 February 2019, 10:29:16 »
I say it again... FIXED layouts please. Swiss cheese plates can be had from every single vendor, we don't need more of that crap. Make this premium grade stuff for people who knows what they want.
If you can handle it, add more layouts but as different plates.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #82 on: Tue, 19 February 2019, 10:58:22 »
I think having a universal layout would do the modifiers a bit of disservice with the 4mm. Honestly i think you should do a poll and collect interest in layouts, unless the batch # does not effect price on quantities this low and made-to-order is fine. Unless you are partnering with a vendor, i imagine the GB participation will be small.
Offline KevlarBear
« Reply #83 on: Tue, 19 February 2019, 11:35:45 »
Based on the imgur album of the layouts I'd be interested in picking up this plate :thumb:
Offline Minterly
« Reply #84 on: Tue, 19 February 2019, 12:35:04 »
+1 Rose Gold!
Offline GigaFlop
« Reply #85 on: Tue, 19 February 2019, 20:55:15 »
I'm interested, depending on price. I've got a nice bronze 60% case waiting for a build, but I might hold it off a while longer.
Oh god why did my wallet get so thin
Offline Puffiin
« Reply #86 on: Thu, 21 February 2019, 21:02:25 »
Very interested, looks like it would be a great addition to a board
« Last Edit: Sat, 23 February 2019, 13:00:33 by Puffiin »
Offline ilouis_07
    • ILUMKB
« Reply #87 on: Tue, 26 February 2019, 23:10:39 »
Sample is out !
Matte sandblast finished
Engraved logo
从我的 iPhone 发送,使用 Tapatalk
Offline kakiharaOne
Re: [IC] TYL 4mm Brass Plate, Time to Enhance Your 60% Keyboard(sample updated)
« Reply #88 on: Tue, 26 February 2019, 23:29:13 »
Yes, please!
    • My Twitch
« Reply #89 on: Tue, 26 February 2019, 23:54:23 »
So awesome! Cannot wait to get one.
Noticed any issues so far? Are the sharp corners an issue for case fitment?
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #90 on: Wed, 27 February 2019, 00:33:45 »
fuc thats thicc  :p :p :p :p
I love your deskmat there too
Offline nasp
« Reply #91 on: Wed, 27 February 2019, 00:53:05 »
Are you taking custom orders? I could use boardwalk polycarb or carbon fiber plate.
Offline ZyBeR
« Reply #92 on: Wed, 27 February 2019, 02:29:32 »
Looks awesome!!
Offline bobdenard
« Reply #93 on: Wed, 27 February 2019, 04:37:19 »
Can’t wait!
Offline MLH
« Reply #94 on: Wed, 27 February 2019, 12:46:05 »
Damn, that's one thick boi, what's it weigh?
+1 interest
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #95 on: Wed, 27 February 2019, 13:46:47 »
That looks awesome.
I'm in for 3 or 4.
Offline ilouis_07
    • ILUMKB
« Reply #97 on: Wed, 27 February 2019, 18:56:00 »
Sample is out! https://uploads.tapatalk-cdn.com/20190227/31f69592143c711899a78cc8144277b6.jpg
Matte sandblast finished: https://uploads.tapatalk-cdn.com/20190227/15a26e34dbfd29304b6c0def45714b8b.jpg
Engraved logo: https://uploads.tapatalk-cdn.com/20190227/bb6ebffc71ed91d5c4bd0e62941c4acd.jpg
No chance for ISO?
Will do separate layouts, I don’t like universal plate. This is just sample layout.
Offline dr_unconscionable
    • [sqeleton]
« Reply #98 on: Thu, 28 February 2019, 02:37:19 »
At first I was like "okay, thick plate is probably nice, but I'm not planning to build another 60%"......
.......but that sample plate looks incredible and I would totally build a new 60% to use it.
Offline fer.real
« Reply #99 on: Thu, 28 February 2019, 05:23:39 »
I'm really looking forward to this.  Are you going to offer different finishes?  I'd like a glossy, polished finish if you offer it.
