Author Topic: Guide to modify USB to look like audio?  (Read 1636 times)
Offline SlamMakanen
« on: Wed, 23 January 2019, 04:12:19 »
Hi everyone. A while back I discovered a guide on modifying a USB cable to look like an audio one (that I often see in keyboard pics). Now that I want to find it again I cannot. Can anyone point me in the direction of how to do this please?
Edit: Example attached from a currently running GB (unsure if I have to give credit or should avoid naming another GB, so will not for now)
« Last Edit: Wed, 23 January 2019, 04:15:55 by SlamMakanen »
Offline mattlach
Re: Guide to modify USB to look like audio?
« Reply #1 on: Wed, 23 January 2019, 19:16:24 »
I'd ask the OP in this thread.
Only other place online Google Image Search finds the image you have below.
IBM Beamspring > IBM Model F > IBM Model M > All Cherry MX, Alps and Topre > Rubber Dome & Scissor Switches.
« Reply #2 on: Wed, 23 January 2019, 19:25:09 »
It's a yarbo connector with a USB port glued into it. You can buy em on taobao.
