Author Topic: hot swap pcb 60%  (Read 9321 times)
Offline _GMK_
  • not affiliated with GMK
hot swap pcb 60%
« on: Fri, 25 January 2019, 07:30:20 »
Hello, I'm looking for a 60% hot swap pcb, with ISO support and open source firmware (tmk or qmk).
Do you have suggestions to share?
QMK, not ISO??
KBDfans KBD6x hot swap pcb
https://kbdfans.cn/collections/pcb/products/kbdfans-kbd6x-hot-swap-pcb
not open source
GK64 RGB 60% 64keys hot swap PCB
https://kbdfans.cn/products/gk64-rgb-60-64keys-hot-swap-pcb
not open source
KBD6X RGB v2 WKL HOT SWAP 60% DOUBLE TYPE-C PCB
https://kbdfans.cn/products/kbd6x-wkl-hot-swap-60-double-type-c-pcb
QMK, ISO
HS60 Hotswap 60% PCB (V2) https://mechboards.co.uk/shop/all/hs60-pcb/
QMK, ANSI
1UP RGB 60% PCB HSE (hot swap edition) ANSI
https://www.1upkeyboards.com/shop/controllers/1up-rgb-pcb-hse/
switches that I'll test :-)
KBDfans T1 Tactile Switch
https://kbdfans.cn/products/gb-kbdfans-t1-tactile-switch-10pies
Offline jtPox
Re: hot swap pcb 60%
« Reply #1 on: Fri, 25 January 2019, 07:33:50 »
According to the QMK configurator, the firmware actually supports the HS60 V2.
https://config.qmk.fm/#/hs60/v1/LAYOUT_60_ansi
Under the "keyboard" dropdown, you can find "hs60/v2"
Edit: Didn't fully read your post, you did state that the PCB supports QMK. My bad.
« Last Edit: Fri, 25 January 2019, 07:45:13 by jtPox »
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #2 on: Fri, 25 January 2019, 08:05:22 »
HS60 supports VIA - the first 60% to do so :)
Offline _GMK_
« Reply #3 on: Fri, 25 January 2019, 08:06:56 »
What is VIA support?
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #4 on: Fri, 25 January 2019, 08:10:53 »
It's a visual GUI frontend to QMK. No flashing required. We'll have a video up soon.
