Author Topic: Gateron housing replace with cherry  (Read 1851 times)
Offline chuckschumer
« on: Mon, 28 January 2019, 23:59:01 »
Just a quick Q. I'm new here so I would need a little of your help. My cherry MX speed are a lil 2 fast so i bought some transparent top gaterons. But i ordered by mistake bottom black housing gateron so my lights on my keyboard SMD wont reflect well. So my Q is can you replace that housing with the bottom one of my cherry mx speed rgb.
 Appreciated if i can get 1 yes or no. Thank you.
« Last Edit: Tue, 29 January 2019, 00:02:33 by chuckschumer »
Offline Sup
Re: Gateron housing replace with cherry
« Reply #1 on: Tue, 29 January 2019, 00:58:16 »
Yes  ;). But changing housing won't change anything about the activation speed.
current
Coming soon
« Reply #2 on: Tue, 29 January 2019, 01:11:36 »
Ty,  I only need it for the led to look brighter and I was talking about the bottom one not the top one. I bought many different gates that I test now 😏
« Last Edit: Tue, 29 January 2019, 01:16:57 by chuckschumer »
Offline ander
  • I type, therefore I am
« Reply #3 on: Sun, 03 February 2019, 05:39:59 »
I'm sure you'll get this all figured out and everything will be fine—but please promise us you'll get outside now and then too, okay?
