Author Topic: QuickerTek iPad Charge Monitor  (Read 5084 times)
Offline itlnstln
« on: Thu, 13 May 2010, 10:57:36 »
Check it.  It works with more than just iPads, and it seems pretty useful.  You can see if your Model M is going to tank your system.
Offline Rajagra
« Reply #1 on: Thu, 13 May 2010, 12:17:06 »
See. That's what happens when you don't use gold-plated USB connectors, Apple!
Offline ricercar
  • mostly abides
« Reply #2 on: Thu, 13 May 2010, 12:50:55 »
I have the USB toaster, too. Have you opened the box yet?
Offline itlnstln
« Reply #3 on: Thu, 13 May 2010, 13:02:53 »
That's hilarious.  "Personal Debris Removal Systems."  Awesome.
Offline EverythingIBM
« Reply #4 on: Thu, 13 May 2010, 17:08:16 »
Quote from: itlnstln;181963
Okay, USB power charging is the stupidest thing ever invented. If I'm not mistaken, the CPU has to cycle the voltage needed through itself and then to the USB port.
There are things called "outlets".
Offline ch_123
« Reply #5 on: Thu, 13 May 2010, 17:44:03 »
You are mistaken.
Surprise surprise.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #6 on: Thu, 13 May 2010, 17:48:23 »
I strongly advise that nobody attempt to plug USB devices directly into wall outlets.
kishy.ca
Offline InSanCen
« Reply #7 on: Thu, 13 May 2010, 18:19:39 »
Quote from: EverythingIBM;182144
Yup, incredibly mistaken... Why on earth would the voltage need to go through the CPU?
I love USB charging. One little 1A wall wart, a resistor and a Female USB port, and 70% of my rechargeable products are good to go. I am also going the extra mile, and replace 2 of my single sockets with combined mains/USB sockets.
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline ch_123
« Reply #8 on: Thu, 13 May 2010, 18:22:12 »
The CPU is like a pump that sends electricity around the motherboard, amirite?
Then again, the Greeks thought that the brain pumped around coolant for the heart or something like that.
Offline Rajagra
« Reply #9 on: Thu, 13 May 2010, 18:33:17 »
Are you thinking of how the host questions the USB device to see how much power it needs, then decides whether or not to enable power?
Offline ch_123
« Reply #10 on: Thu, 13 May 2010, 19:04:03 »
Well, USB ports can power stuff when the system is off (in some cases anyway).
« Reply #11 on: Fri, 14 May 2010, 16:45:34 »
Quote from: ch_123;182159
You are mistaken.
Surprise surprise.
Whenever I plug in a USB device into most computers, they emit this weird high pitched ring. It's annoying. Only does it when the device is first plugged in.
