Author Topic: Hot swap mod on KUL ES-87  (Read 1664 times)
Offline navy2x
« on: Sat, 02 February 2019, 17:28:34 »
Anyone know if possible or even reasonable to mod a kul es-87 to make it hot swappable? I got in on the mill mix gb on Reddit and hoping I can do it. I’d like to make that board a tester for different switches. Thanks.
Offline RobotCandyCompany
    • RCC Instagram
Re: Hot swap mod on KUL ES-87
« Reply #1 on: Sat, 02 February 2019, 18:42:25 »
You should be able to desolder all the switches and put in your sockets. I can't think of why that wouldn't work.
MX and Topre caps are available at http://robotcandy.company/
Follow us on Instagram for release announcements
Offline navy2x
« Reply #2 on: Sat, 02 February 2019, 19:48:14 »
Ok cool. That was my plan, desolder and add the mill max sockets.
