Author Topic: m122 issues  (Read 1710 times)
Offline Drake9800
m122 issues
« on: Mon, 04 February 2019, 09:36:28 »
howdy folks!
It's been an adventure with this unit from initial cleaning to complete resto and bolt mod but ONE issue persists that keeps me from using this as my daily driver.
The "i" key would often register twice "ii" with one keystroke (stretched spring right? enough to warrant unbolting everything and swapping spring/foot with another... done! still it seems I am having the same issue especially at full typing pace AND now the key won't register without bottoming out.
Is this is a membrane issue? both sheets and traces were clean and free of debris. what else can I do to test aside from complete disassembly again?
Thank you for your help and correct me if this is the wrong sub forum
*As a thank you, please enjoy this IBM wallpaper I made*
Offline Drake9800
Re: m122 issues
« Reply #1 on: Mon, 04 February 2019, 11:43:27 »
Update, It is apart once more and I have tested continuity for each membrane from start to finish on that trace and no interruption. Not sure at this point what else to be looking for :/
