Author Topic: 40% CaseLess case help.  (Read 2925 times)
Offline Ridingmac
« on: Mon, 04 February 2019, 12:50:08 »
Starting my first 40% pretty soon. Im wanting handwired. I want something like this. What would you use to close the underside since ill be handwiring it.
Sent from my SM-G960W using Tapatalk
Offline nevin
Re: 40% CaseLess case help.
« Reply #1 on: Mon, 04 February 2019, 13:40:06 »
spaced plates, something like this.
212171-0
keeb.io has the Laplace kit, but there's a bit of a bezel around the board, but it's a 40% with that style frame (spaced plates)
https://keeb.io/collections/frontpage/products/laplace-40-staggered-keyboard
Offline Ridingmac
« Reply #2 on: Mon, 04 February 2019, 20:53:02 »
Awome. Thanks for great and fast reply
Offline nevin
« Reply #3 on: Mon, 04 February 2019, 22:55:27 »
if you can't find plates that will fit the layout you want, you could always do keyboard layout editor & swill to get the files needed to have your own custom plate cut.
Keyboard layout editor JD40 as a starting point
Swill Plate & Case Builder
Ponoko another online laser cutter
