Author Topic: Lets Split encoder support  (Read 1515 times)
Offline Pyne
« on: Tue, 05 February 2019, 15:49:29 »
Hey,
just wanted to know if the QMK / Lets Split Keyboard does support a rotary encoder on both sides. Couldn‘t find anything about this anywhere.
Thanks in advance!
Pyne
Offline Pyne
Re: Lets Split encoder support
« Reply #1 on: Fri, 08 February 2019, 08:37:22 »
No one??? :((((
Offline DanielOh
« Reply #2 on: Fri, 08 February 2019, 17:29:44 »
I dont think they do, as most of the keyboards.
However, it it not hard to make one, by using teensy.
Offline Pyne
« Reply #3 on: Sun, 17 February 2019, 03:42:10 »
Ah ok. As far as i could figure out it does support it on the master side
