Author Topic: wireless hot swappable keyboard  (Read 14587 times)
Offline killermax
« on: Wed, 06 February 2019, 02:48:00 »
Hi,
I've been using a ducky zero Blue SW for year. Ive been moving things around my desk very often so i felt like i need a wireless keyboard.
Are there any hot swappable wireless keyboard out there. Ive been searching it for a couple of weeks not and cant seem to find one.
If i cant, then can i buy any mechanical wireless kbd and swap out the original switches for what i want via soldering?
Offline dexie
ISO Life
Offline killermax
Re: wireless hot swappable keyboard
« Reply #2 on: Wed, 06 February 2019, 22:50:09 »
https://www.aliexpress.com/item/GH60-GK61-RGB-Hot-Swap-Independent-Driver-Wired-and-Bluetooth-Tyce-C-ANSI-Mechanical-keyboard-DIY/32942776819.html probably your only option
Are there anything bigger than a 60% layout that is wireless? I dont really mind the soldering. I just need it to be wireless.
Offline dexie
« Reply #3 on: Thu, 07 February 2019, 00:20:59 »
ISO Life
Offline intothesorrow
« Reply #4 on: Fri, 08 February 2019, 13:53:29 »
GK84 seems to meet your requirements - it is hot-swappable, wireless and more than 60%. https://kprepublic.com/products/gk84-mechanical-keyboard-75-dye-sub-keycap-wooden-custom-light-rgb-ink-paintingsakura-lotus-bluetooth-4-0-usb-dual-mode
And you surely can buy a bluetooth keyboard and solder the switches you want. For example, Ganss 87D keyboard.
