Author Topic: 60% RGB PCB  (Read 2810 times)
Offline GrzlyG
60% RGB PCB
« on: Thu, 07 February 2019, 22:54:44 »
Hey, I'm new here. I have a question, can anyone tell me what the best backlit RGB 60% PCB is?
When I say best - I'm talking overall board quality and how good the RGB/programming/software is. My top picks for boards right now are the Vortex POK3R (and yes I know this is more than just a PCB) and the GK64. Let me know. Thanks  ;D
Offline Sup
Re: 60% RGB PCB
« Reply #1 on: Fri, 08 February 2019, 01:45:40 »
Zeal60 RGB USB C and QMK compatible. This is probably the best RGB Backlit 60% PCB you will find.
current
Coming soon
Offline Aerizu
  • Professional Lurker
Re: 60% RGB PCB
« Reply #2 on: Fri, 08 February 2019, 04:11:58 »
+1, not to mention it can be configured using VIA configurator.
Offline dexie
Re: 60% RGB PCB
« Reply #3 on: Fri, 08 February 2019, 06:54:53 »
/thread
If you want "the best" there are just no other options. If you are willing to go a little cheaper HS60, DZ60RGB and KBD6X RGB are all pretty decent choices. GK64 if you are crazy about layouts
ISO Life
Offline GrzlyG
Re: 60% RGB PCB
« Reply #4 on: Fri, 08 February 2019, 12:51:41 »
Do you know if the GK64 is QMK compatible?
