Author Topic: Plate arrived!  (Read 2316 times)
Offline DanielOh
Plate arrived!
« on: Mon, 11 February 2019, 18:01:51 »
Plate finally arrived, One question is what kindda screw size does most custom keyboards use? Cause I just used m2(or 2pi) screw. Is it okay?
Offline nevin
Re: Plate arrived!
« Reply #1 on: Mon, 11 February 2019, 19:02:56 »
2mm. That's fine, easy stuff to find. More importantly... what size are the holes in the plate. Get hardware to match that.
Offline DanielOh
Re: Plate arrived!
« Reply #2 on: Mon, 11 February 2019, 19:10:03 »
switch hole is 14x14
screw hole is m2, or 2pi
Offline nevin
Re: Plate arrived!
« Reply #3 on: Mon, 11 February 2019, 20:37:03 »
Yeah, meant screw holes. 2mm is fine, easy hardware to find.
Offline nevin
Re: Plate arrived!
« Reply #4 on: Mon, 11 February 2019, 20:55:19 »
my Viterbi (same style, dual plate case) has 12mm standoffs, just for reference of plate spacing.
Offline DanielOh
Re: Plate arrived!
« Reply #5 on: Tue, 12 February 2019, 10:30:24 »
Oh I see! Thanks
Offline nevin
Re: Plate arrived!
« Reply #6 on: Tue, 12 February 2019, 10:50:13 »
no problem.
