Author Topic: [IC] GMK Minimal  (Read 150160 times)
Offline Poesjuh
Re: [IC] GMK Minimal
« Reply #150 on: Tue, 26 February 2019, 10:07:37 »
Sets dropping ISO one by one isn't helping either... The minimum amount of caps required for iso is 4 caps... Pipe x2, enter and short left shift. Really not that hard to include those.
Offline eskimojo
    • KeycapLendar
« Reply #151 on: Tue, 26 February 2019, 10:25:05 »
sure, but that's only the physical layout - any actual ISO layout will involve other keys and thus legends.
Offline Poesjuh
[IC] GMK Minimal
« Reply #152 on: Tue, 26 February 2019, 11:13:34 »
I know, but those could be ignored. Those 4 are the minimum to simply make it work. Yes legends will be wrong, but that’s the case for a -lot- of European keyboard lay-outs. Iso-de, French, Portugese, Norde, Iso-UK, they all require different legends. A kit to include all of this does make it expensive I can agree on that. Afaik there isn’t a single country in Europe that uses us-ansi, even here in The Netherlands we have custom legends (€ on the E) and you see iso enter on Dutch keyboards often.
But 4....... caps just to make iso enter and split left shift possible, can’t be that hard/expensive? Precisely the 4 that are included in the numpad/iso kit.
« Last Edit: Tue, 26 February 2019, 11:17:27 by Poesjuh »
Offline nasp
« Reply #153 on: Tue, 26 February 2019, 11:45:05 »
Seeing as how OP is in Europe and uses ISO, I'm sure he understands what you all are going through.
Offline OtherAndrew
« Reply #154 on: Wed, 27 February 2019, 14:11:22 »
imagine being french
oui oui
Offline rondg
« Reply #155 on: Wed, 27 February 2019, 17:19:40 »
I know that this is supposed to be minimal but seeing the renders on the 910, I think a gold/brass keycap will look really good as an artisan
Offline kakiharaOne
« Reply #156 on: Wed, 27 February 2019, 19:13:18 »
You can get the brass Rama keycap currently available on the Bento GB.
Offline etong415
« Reply #157 on: Wed, 27 February 2019, 20:24:16 »
A white anodized aluminum Rama XO would look clean with this set
Offline kakiharaOne
« Reply #158 on: Wed, 27 February 2019, 21:39:36 »
Actually... looks like there will be two Rama keycaps for this GB (black/white and brass): https://dixiemech.com/shop/gmkminimal
Apparently starting tomorrow?
Offline xkhol
« Reply #159 on: Wed, 27 February 2019, 22:10:53 »
Interested! Is Dharma real?! That is my dream board. PLEASSSSE
Sent from my Pixel 3 XL using Tapatalk
It will be after CNY ;)
Can’t wait for this! I just spent way too much time googling trying to find out more about it.
Offline silversung
« Reply #160 on: Wed, 27 February 2019, 22:15:14 »
Woah, GB starts tomorrow? That's fast!
Offline AlcoholEnthusiast
« Reply #161 on: Wed, 27 February 2019, 23:06:11 »
Glad this is starting so quick! Do we have pricing on the RAMA caps yet? Both look great. I don't see them on the drop down bar on Dixiemech though
Offline Rogue_Jellybean
« Reply #162 on: Thu, 28 February 2019, 00:26:29 »
There was a link on the Diximech page, I think it said $56 for the PVD one and $58 for the enamel.
« Reply #163 on: Thu, 28 February 2019, 03:54:38 »
Thanks, I'm a dummy. I assumed it would be on the same page like NK and Bento.
Offline Olitender
« Reply #164 on: Thu, 28 February 2019, 03:56:59 »
Yea, you dummy .
Going into heat.
Offline tectonicplate
« Reply #165 on: Thu, 28 February 2019, 10:24:38 »
With the ortho kit, what row profile are ESC and TAB? The standard Planck has a R2 TAB and R3 ESC… although the render implies the reverse (R2 ESC and R3 TAB). I'm hoping it's the standard… ? Should we also assume that ENTER is the standard R4 (not R3)?
Offline oldcat
  • 65% is Life
« Reply #166 on: Thu, 28 February 2019, 10:58:17 »
GB is live: https://dixiemech.com/shop/gmkminimal/
$99 at 500 sets, lets go
Offline janglad
  • qoda.studio
    • Clavier.xyz
« Reply #167 on: Thu, 28 February 2019, 10:59:13 »
Yes.... GB thread has been waiting for mod approval for a couple of hours now, hopefully it gets up soon.
Offline Dovan1405
« Reply #168 on: Thu, 28 February 2019, 12:15:34 »
Just ordered mine exciting
Offline kakiharaOne
« Reply #169 on: Thu, 28 February 2019, 13:28:08 »
Any info on the Dharma? Mainly price ballpark? I don’t typically use numpad but kinda dig this layout. To buy Minimal + or not...
Offline Rumblehotep
« Reply #170 on: Thu, 28 February 2019, 13:29:01 »
Esc and Tab on the minus kit should swap profiles  :confused:
Love the white enamel rama cap, getting base kit at least
Offline oldcat
  • 65% is Life
« Reply #171 on: Thu, 28 February 2019, 14:01:57 »
bought as soon as I saw it live :)
Offline raphaelf
« Reply #172 on: Thu, 28 February 2019, 14:18:00 »
This. Support the default planck/preonic layout =)
Offline janglad
  • qoda.studio
    • Clavier.xyz
« Reply #173 on: Thu, 28 February 2019, 17:34:45 »
GB thread is live! Please move all discussion there
https://geekhack.org/index.php?topic=99624.0
Offline baoduy23
« Reply #174 on: Sat, 02 March 2019, 05:37:23 »
I need Muted R2 :( that's all
Offline ptykozoon
« Reply #175 on: Wed, 13 March 2019, 22:46:08 »
Need this for my Rama Milk, looks clean af
Likewise
BTW is there a WS1 Cherry logo cap?
Offline chriszhu
  • (* ̄(エ) ̄*)''
« Reply #176 on: Thu, 25 April 2019, 19:44:16 »
Missed out on this, now I have to wait for it to show up on r/mechmarket
Offline eskimojo
    • KeycapLendar
« Reply #177 on: Fri, 26 April 2019, 03:19:30 »
Vendors should have extras once the set actually ships.
also this is the IC thread
