Author Topic: Adjusting IBM Trackpoint sensitivity?  (Read 6398 times)
Offline Input Nirvana
« on: Fri, 14 May 2010, 23:07:34 »
Myself and several others here have purchased some IBM KPD8923 keyboards primarily to remove and use the trackpoints in mod projects. A question has come up about being able to adjust the responsiveness of the trackpoints to make them operate with less pressure, particularly for those that may have RSI issues.
Does anyone here have any info/thoughts/direction on this? Any help is appreciated.
Offline EverythingIBM
« Reply #1 on: Sat, 15 May 2010, 01:00:16 »
IBM has software to increase the sensitivity of trackpoints; see if you can get any of it to work with the hardware.
« Reply #2 on: Sun, 16 May 2010, 23:47:18 »
Quote from: EverythingIBM;182521
Thanks, will look for. On a Mac it will be a problem though :(
Offline ricercar
  • mostly abides
« Reply #3 on: Mon, 17 May 2010, 00:05:28 »
Have you tried that MacOS mouse utility by Alex someone-russian-ovitch? He's been maintaining it since the CompuServe days, it works with 99.999% of the cursor control hardware out there, and it's bound to affect the TrackPoint somehow.
« Reply #4 on: Mon, 17 May 2010, 00:27:47 »
Steermouse, USB Overdrive, Controllermate,
Those are the Mac ones I'm familiar with. Thought I might find one that works on Mac/PC. I'll start checking how they work and look for what you mention.
Offline gator456
« Reply #5 on: Mon, 17 May 2010, 09:10:10 »
I am one of the others.....
I downloaded tpcom.exe from here:
http://wwwcssrv.almaden.ibm.com/trackpoint/download.html
I was able to poll the TP and read some of the status registers.  Ex:
tpcom.exe f2 r
tpcom.exe eb r r r
tpcom.exe e9 r r r
According to this document:
http://wwwcssrv.almaden.ibm.com/trackpoint/files/ykt3dext.pdf
I should be able to change the sensitivity with:
tpcom.exe E2 81 41
I get an error (dont have exact error right now).
Offline ricercar
  • mostly abides
« Reply #6 on: Mon, 17 May 2010, 12:19:55 »
Quote from: gator456;183117
Hey, that's down the road from me ... 20 miles.
« Reply #7 on: Thu, 20 May 2010, 00:10:30 »
Quote from: input nirvana;183008
Well try ripping out one of those Apple trackballs they used to supply on their macbooks. That might work... and mount it on the top right corner of the keyboard.
« Reply #8 on: Thu, 20 May 2010, 16:46:47 »
I don't think I've ever seen that. I was a little familiar with Macs, but didn't really jump aboard until they started using Intel chips 4 years ago.
« Reply #9 on: Thu, 20 May 2010, 21:04:54 »
Quote from: input nirvana;184964
Please don't remind me of rosetta; I'd rather push cactus needles in my skull.
And yeah, old macbooks had trackballs; that's why IBM spent so much time to develop the trackpoint so they wouldn't be copying apple.
