Author Topic: Leopold FC750R vs FC980M  (Read 4210 times)
Offline sneakyfox
« on: Tue, 19 February 2019, 07:43:54 »
Is there any difference between the Leopold FC750R and FC980M keyboards -  aside from the obvious difference in key layout?
Is the build the same? Same quality?
Offline wholypantalones
  • text and icon mods plz.
Re: Leopold FC750R vs FC980M
« Reply #1 on: Tue, 19 February 2019, 08:43:18 »
Same exact keyboard, just different layout. The PD versions will have pbt caps as opposed to abs plastic.
« Reply #2 on: Tue, 19 February 2019, 08:44:04 »
whoops.
Offline sneakyfox
« Reply #3 on: Tue, 19 February 2019, 09:35:59 »
Offline Entropia
« Reply #4 on: Tue, 19 February 2019, 15:11:59 »
whoops.
I may be wrong, but I think all of their keyboards have pbt keycaps, the PD models having double shot pbt keycaps.
« Reply #5 on: Tue, 19 February 2019, 16:15:24 »
whoops.
Yes.
