Author Topic: USB connector and custom cable  (Read 1425 times)
Offline Grandmasternoob
« on: Wed, 20 February 2019, 10:54:57 »
Hi guys! need your help
My keyboard has a micro usb connector that connects to the pcb https://imgur.com/a/VD89Yth
will the cable made according to this scheme work? https://geekhack.org/index.php?topic=44924.0
USB connector has 5 wires, and the cable is made of 4, everything will work? :blank:
Offline Tactile
Re: USB connector and custom cable
« Reply #1 on: Wed, 20 February 2019, 11:23:02 »
You only need four wires. The fifth wire you see is the cable shield - you don't need to worry about it.
REΛLFORCE
« Reply #2 on: Wed, 20 February 2019, 11:43:18 »
thanks, I'm worried about the pcb) if wrong will make cable
