Author Topic: How do you open the case of the Realforce RGB?  (Read 3812 times)
Offline zstsc
« on: Thu, 28 February 2019, 00:09:13 »
I manage to open all the tabs at the top part of the back which is visible and unscrew the warranty area.
how do you open the bottom part of the back? it seems attached.
« Last Edit: Thu, 28 February 2019, 00:11:57 by zstsc »
Offline Sup
Re: How do you open the case of the Realforce RGB?
« Reply #1 on: Thu, 28 February 2019, 12:47:52 »
Google is your friend my dude try it. On the bottom side there seems to be also some clips. Also the sticker next to the cable there is a screw under it you will void your warranty removing the sticker. Any reason for disassembling your Realforce RGB? Maybe you could try to watch this video.
current
Coming soon
Offline zslane
« Reply #2 on: Fri, 01 March 2019, 12:04:33 »
Disassembling the board is necessary for installing silencing rings.
There are snaps along that bottom but they are very hard to see. You have to just pull back a section of the bottom, stick a credit card in, and slide along the bottom to pop open the snaps. It takes a bit of force, but that's how you do it.
