Author Topic: Polycarbonate, how easy is it to obtain and use?  (Read 3215 times)
Offline TINYisTOXIC
« on: Thu, 28 February 2019, 11:28:35 »
Polycarbonate, a strong plastic, much better than acrylic or generic abs cases seems to be nonexistent when it comes to 60% cases. I was wondering if it was possible to have it cut, or made for a 60% keyboard. Is it strong enough to be used as a plate? How pricey would it even be?
Re: Polycarbonate, how easy is it to obtain and use?
« Reply #1 on: Thu, 28 February 2019, 12:25:34 »
My makerspace does not allow PC to be cut in the laser-cutter. The plastic smokes and catches fire easily. Smoke is very bad for a laser-cutter because it settles on the mirrors making them absorb the laser instead of reflecting it.
PC is sometimes laser-cut industrially though, but I think most firms do only sheets that are much thinner than what you would need for a plate.
So, likely, you would have to CNC-route it, which is more expensive, and you wouldn't get those clear, crisp edges that you would get with acrylic.
The plastic is also more expensive to begin with.
« Last Edit: Thu, 28 February 2019, 12:27:14 by Findecanor »
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #2 on: Thu, 28 February 2019, 12:53:21 »
Because of the reasons stated above, producing polycarbonate plates and parts is as expensive as aluminum parts.
Offline nevin
« Reply #3 on: Thu, 28 February 2019, 16:22:58 »
in general, polycarbonate is stronger yes, but more flexible without breaking. most thin sheets you can fold in half without them snapping/breaking. it's not as stiff/rigid as acrylic. Easily vacuum formable as well.
... also used in bullet proof glass, as well as MANY other applications.
Offline DGX_Shin
« Reply #4 on: Thu, 28 February 2019, 21:11:38 »
I have already make a Numpad case with polycarbonate ;).
