Author Topic: New Poker ii programming question  (Read 1330 times)
Offline myro
« on: Thu, 28 February 2019, 15:01:27 »
Does anyone know if I can set my board up in a way so I can switch between the normal layout and function of the keys, and a second layout where the keys: o, k, l, and ; are the arrow keys without pressing the fn and pn to activate the arrow keys?
Offline myro
Re: New Poker ii programming question
« Reply #1 on: Thu, 28 February 2019, 15:47:53 »
I figured this out in case anyone else has the same question.
To do this you need to enter a new layer for programming : fn+right shift
Then you need to enter programming mode: fn+ right control
Then press the key you want to program: O
Then press the key you want programmed to that key: fn + w
Then press pn
Do any more programming you want to do using this method.
Then to close programming press fn + right control again.
Now in this programming layer O, when pressed, will be Up arrow.
