Author Topic: Sun Type 7 replacement keyboard caps  (Read 3016 times)
Offline ultra24
« on: Sat, 02 March 2019, 06:09:46 »
Hello:
I'm looking for a source of replacement keyboard caps for the Sun Type 7 keyboard, used, new or custom.
Any idea as to where I could get them?
I have not been able to find out what type (spec) they are.
Thanks in advance.
U24
Re: Sun Type 7 replacement keyboard caps
« Reply #1 on: Sat, 02 March 2019, 06:47:12 »
Welcome to geekhack :)
According to the Deskthority wiki this board uses a rubber dome with slider switch which doesn't sound good for finding new caps.  If you post a pic of the back of the removed cap and the hole(?) it came out of someone might recognise it as being compatible with another board which you might be able to find.  Be very careful when removing caps - you want to lift both sides (or top/bottom) at the same time so it lifts out straight or you might snap the stem.
Offline ultra24
« Reply #2 on: Sat, 02 March 2019, 17:57:51 »
Hello:
Welcome to geekhack
Thank you.
And for the fast reply also.  =-)
... a rubber dome with slider switch
Yes, that's what it looks like.
Nice and springy.
AAMF, at first I thought they had springs and not domes.
...  a pic of the back of the removed cap and the hole
There they are.
Caps come off easy.
The slider I'd think is not necessary to remove.
... someone might recognise it as being compatible with another board
Never seen this type of caps.
I've taken apart quite a few HPs and IBMs but don't recall any like these.
Any help with this will be greatly appreciated.
Thanks in advance.
U24
« Last Edit: Sat, 02 March 2019, 18:04:22 by ultra24 »
