Author Topic: E6.5 - 65% custom keyboard (GROUP BUY FINISHED )  (Read 328186 times)
Offline wellbeing44
  • kebord good kebord fun yum yum
Re: E6.5 - 65% custom keyboard (Sorted down)
« Reply #400 on: Wed, 03 April 2019, 01:25:22 »
looks like I was late on this one...any chance of an E8 GB in the future?
There already was an E8, but it was ran by someone else. It...didn't go so well...
https://geekhack.org/index.php?topic=87572.0
JFC, that reads like a horror story.
yup that's why I'm hoping we get a more reliable GB for it a second time around
I believe all the ones directly run by Exclusive were reliable, so we're in a good position.
Offline daviddoi
« Reply #401 on: Wed, 03 April 2019, 02:46:11 »
is this gb already at its limit? really interested in a e white one 🥺
Offline dantambok
« Reply #402 on: Wed, 03 April 2019, 06:42:08 »
lol
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline Sic_Alpha
« Reply #403 on: Wed, 03 April 2019, 11:50:50 »
Yes it's closed.
Offline Blank
« Reply #404 on: Thu, 04 April 2019, 06:09:55 »
Does the spacebar use 6.25U or 7U stabs?
Offline donut_sauce
« Reply #405 on: Thu, 04 April 2019, 06:18:21 »
depends which layout you chose
Offline cldskt
  • Wallet and hobby aren't friends
« Reply #406 on: Thu, 04 April 2019, 06:34:57 »
lol
Hey be nice
"Addiction is buying the things that I don't need with the money I don't have." - me
"Spending $500 on your first custom is justified." - also me
Offline dantambok
« Reply #407 on: Thu, 04 April 2019, 06:35:27 »
Stuff  I have
100+ GMK sets
Offline BAS1C
« Reply #408 on: Thu, 04 April 2019, 09:33:39 »
Yes, do not worry. There have been 2 rounds of E6-v2 and a E7 run since then and they all went very smoothly! E8 was not run directly thru exclusive, and all the others were. As long as he handles it all, do not worry :)
Offline Blank
« Reply #409 on: Thu, 04 April 2019, 09:58:08 »
If it's the wk with block layout, what would that use ?
Offline cldskt
« Reply #410 on: Thu, 04 April 2019, 12:36:45 »
Still depends on the bottom row.
Refer to the layout pic in the OP.
« Last Edit: Thu, 04 April 2019, 12:38:31 by cldskt »
Offline Blank
« Reply #411 on: Thu, 04 April 2019, 12:47:45 »
Where in the order form would I see which bottom row was chosen? Isn't wk with block layout the bottom row?
Offline eyedrop
« Reply #412 on: Thu, 04 April 2019, 13:45:31 »
If you look at the layout from the OP, for WK with block layout, you can build:
1.25 | 1.25 | 1.25 | 6.25 | 1.25 | 1.25
or
1.5 | 1 | 1.5 | 7 | 1.5
as the bottom row.
Hope this helps.
Offline Blank
« Reply #413 on: Thu, 04 April 2019, 14:23:37 »
or
as the bottom row.
Hope this helps.
Would that mean one is able to use up to 6 stabs bottom row? On the render it only shows 1 stab at the spacebar. Sorry for the maybe obvious questions it is my first time in a gp
Offline nephlock
« Reply #414 on: Thu, 04 April 2019, 14:25:37 »
Only longer keys need a stab, so the 6.25u and the 7u. the other keys do not require stabilizers.
Offline Owl-
« Reply #415 on: Thu, 04 April 2019, 15:55:47 »
Anything 2u and above in keysize will have the opportunity to utilise a stabiliser. The standard stabiliser wire sizes are 2U, 6.25, 7u. The less common is 6U, though findable; your very less common sizes will be anything in between those.
Offline Blank
« Reply #416 on: Thu, 04 April 2019, 16:20:12 »
Ohh I see! How many is the usual amount or how many would u use?
Offline allllaboutyou
« Reply #417 on: Thu, 04 April 2019, 16:42:04 »
hoping he does an E8 run in the future!  :)
Offline Owl-
« Reply #418 on: Thu, 04 April 2019, 17:42:35 »
A standard 60% keyboard will use a total of 5 stabilisers - four 2U and one 6.25u. It's used with the space bar, two shift keys, your enter/return and the backspace.
216637-0
Keys with extra holes will utilise stabilisers. The image below shows the common sizes:
216639-1
How many you would use is dependent on your layout of choice and up to you, ones preference. It can be none at all to your general set of 8 on a full-size standard keyboard or more stabilisers as you peak into custom builds on your keyboard adventures.
Offline EnjoyMyInSec
  • 60% or bust
« Reply #419 on: Fri, 05 April 2019, 07:41:12 »
Hi guys, due to personnal problem I need some money and I'd like to sell my spot, feel free to PM me if you're interested
EDIT : My spot is sold, thanks for all the PM guys !  :thumb:
« Last Edit: Mon, 08 April 2019, 10:31:56 by EnjoyMyInSec »
Offline yur1orlov
« Reply #420 on: Fri, 05 April 2019, 08:00:46 »
Haha looks like you're in luck. Check the post above mine.. e-white guy wants out
Keycult no1rev1 | Keycult no2rev1 | Jane v2 Blue Grey | Kyuu x2 | QXP | Rukia
Offline excluisve
  • Making & Thinking.
Re: E6.5 - 65% custom keyboard (Start manufacturing 8/ April)
« Reply #421 on: Sun, 07 April 2019, 21:32:13 »
we have been wait almost a week ,now is start manufacturing
Offline wellbeing44
« Reply #422 on: Sun, 07 April 2019, 22:07:09 »
I can't wait ;D
Offline fleeceman
« Reply #423 on: Mon, 08 April 2019, 07:10:52 »
What will happen if it is not possible to use our chosen fonts? I noticed that some people picked fonts that don't include the letters/numbers they want to use so I imagine these ones will not be possible.
Offline vicissitude
« Reply #424 on: Mon, 08 April 2019, 08:46:17 »
YES. One big step forward.
Offline excluisve
« Reply #425 on: Mon, 08 April 2019, 09:46:11 »
If you cant find which font you like then i will make it to default fonts
Offline excluisve
« Reply #426 on: Mon, 08 April 2019, 09:47:54 »
One more things,if you still not give me the fonts link plz let me know
Deadline is 15/4 i will start make custom text after deadline .
Offline senryo
  • Problems are challenges.
    • Thic Thock
« Reply #427 on: Tue, 09 April 2019, 14:22:19 »
Thanks for the update! Any new prototypes pictures that help us quench our thirst with it :p?
Offline fleeceman
« Reply #428 on: Fri, 12 April 2019, 05:06:16 »
Does the plate support short left shift? For ISO layouts
Offline misonerdy
« Reply #429 on: Fri, 12 April 2019, 13:08:36 »
Hey everyone! Due to some financial constraints, I am offering up my group buy spot.
I ordered the following:
-Grey case colorway
-Brass plate (pvd gold)
-Weight A/B sandblasted brass
-Name plate (pvd gold)
Please dm or message me if interested! Thank you very much =)
Offline noahf
« Reply #430 on: Fri, 12 April 2019, 20:51:46 »
if it were a pc spot i would buy it for my second 6.5, but i dont think you will have a problem getting rid of it.
Offline quanghuy1200
« Reply #431 on: Fri, 12 April 2019, 21:20:29 »
I do have a PC spot for sale at cost. Pm'ing :)
Offline 3ambutter
« Reply #432 on: Fri, 12 April 2019, 21:59:27 »
-Grey case colorway
PM'd
Reborn60 | Keycult No.1 Rev.1 | SKB60 | TGR x SINGA UNIKORN | GSKT-00
Offline AlcoholEnthusiast
« Reply #433 on: Fri, 12 April 2019, 23:27:40 »
If anyone wanted to trade their spot for a Leaf 60 (2 plate/2pcb, brass weight/plate) lmk. Turns out I'm not a huge fan of 60%
Offline Vadurr
  • Valar Morghulis
« Reply #434 on: Sat, 13 April 2019, 09:49:01 »
Interested in a PC version if anyone decides to give up a spot :)
Offline evoluchanel
« Reply #435 on: Sat, 13 April 2019, 14:27:36 »
Pm
Offline nickaster1
« Reply #436 on: Mon, 15 April 2019, 09:41:47 »
Changing plans so now I知 really in need for a polycarb/brass full plate. Send help pls?
Offline 3ambutter
« Reply #437 on: Mon, 15 April 2019, 18:53:01 »
Looking to take somebody's GB spot for alu grey+brass/PC plate if they decide to opt out. Just send me a PM, ty.
Offline ContaxS2
« Reply #438 on: Fri, 19 April 2019, 17:07:34 »
Just stopping by to say I知 still very excited, I知 in for 2 and no you can稚 have them  :D
Offline noahf
« Reply #439 on: Fri, 19 April 2019, 19:43:40 »
just to be fair, im so excited im trying to buy my 2nd, a pc version. last one fell through, so im still in the market.
Offline evoluchanel
« Reply #440 on: Sat, 20 April 2019, 21:20:34 »
Plans have changed and I'm looking to transfer my spot.
Most accessible on discord: evoluchanel#4975
EDIT: he gone
« Last Edit: Tue, 21 May 2019, 21:03:15 by evoluchanel »
Offline fleeceman
« Reply #441 on: Mon, 22 April 2019, 06:48:57 »
Is it too late to buy an extra nameplate?
Offline excluisve
« Reply #442 on: Thu, 25 April 2019, 21:37:40 »
Yea too late
Offline excluisve
« Reply #443 on: Thu, 25 April 2019, 21:41:28 »
Some update
#Plate finish 60%
#case start CNC
# case carry box manufacturing
#pcb manufacturing
Factory very busy now
Sorry for delay update ,coz this month have some personal things to deal with
Will post more details later when next time go factory to  check .
« Reply #444 on: Thu, 25 April 2019, 22:14:51 »
Some update
#Plate finish 60%
#case start CNC
#pcb manufacturing
hope everything is ok with you exclusive, thanks for the update
Offline aroostercat
« Reply #445 on: Tue, 30 April 2019, 14:41:27 »
Looking for a spot: Grey WKL with brass weight and plate
Message on here or reddit under the same name
Thank you!
Offline petamva
« Reply #446 on: Wed, 01 May 2019, 02:17:58 »
Interested in a PC version WKL with blocker. PM me here or on mechmarket /u/petamva. Thanks!
Offline pumice
« Reply #447 on: Wed, 01 May 2019, 13:55:37 »
Looking for Polycarb/e-black WKL or standard version, let me know here or on reddit u/pumiceminds if your're willing to give up your spot.
Offline binphan161
« Reply #448 on: Wed, 01 May 2019, 17:51:31 »
Also looking for a WKL with block in any color with a brass weight! If anyone wants to sell their spot please let me know :)
Offline Sazuke9
« Reply #449 on: Fri, 03 May 2019, 16:27:16 »
Looking for any PC /w wkl pls pm if anyone wants to give up their spot. Thank you :)
