Author Topic: [IC] -無常- Uncertainty60  (Read 45734 times)
Offline amaddo
Re: [IC] Uncertainty60 with KBDfans (production prototype)
« Reply #50 on: Tue, 11 June 2019, 17:23:48 »
The uncertainty60 prototype is being reproduction by the factory.
Sorry for not updating for a while. :(
Offline EMC Labs
« Reply #51 on: Wed, 12 June 2019, 19:11:05 »
how long do you think until this is available? and please have WKL blockers
Offline amaddo
« Reply #52 on: Thu, 13 June 2019, 08:23:13 »
It is not possible to announce a clear date yet. I'm sorry.
And with regard to the WKL and HHKB blocks that we received a lot from you, we are considering adding them.
We also plan to manufacture a PC version of the case.
Offline amaddo
Re: [IC] Uncertainty60 with KBDfans (Add new picture)
« Reply #53 on: Mon, 01 July 2019, 05:53:10 »
Hi, everyone.
I was received prototype(But Failure).
The image has been updated.
I will update it as soon as we receive the latest proto.
Until then, enjoy the typing sound of this keyboard!
Offline aleck
Re: [IC] Uncertainty60 with KBDfans (Add actual photo & Typing sound link)
« Reply #54 on: Wed, 14 August 2019, 15:39:14 »
...any news?
HHKB Pro 2 Type-S (2016)
Offline amaddo
« Reply #55 on: Fri, 16 August 2019, 06:50:23 »
I I contact KBDfans through Discord on a regular basis (about a week).
And I'm asking for new news and photos of prototypes in production, but KBDfans says they didn't send them from the factory.
I will contact you again tomorrow.
Sorry for being late.
...any news?
Offline equalunique
« Reply #56 on: Fri, 23 August 2019, 09:05:36 »
I am for sure interested, but it depends on the color offered. KBDFans usually has Navy Blue as a choice. I'd go with that, or Orange. HHKB ideal.
Sent from my Ono-Sendai Cyberspace 7 using Tapatalk
« Last Edit: Fri, 23 August 2019, 12:16:38 by equalunique »
Offline EMC Labs
« Reply #57 on: Fri, 23 August 2019, 10:23:15 »
Excited for the PC version and wishing the HHKB and WKL options are added. Now, we just have to wait.
Offline amaddo
Re: [IC] Uncertainty60 (Add HHKB and WKL)
« Reply #58 on: Sat, 31 August 2019, 21:13:51 »
Hi, I will respond to your request.
This is...Add WKL and HHKB design.
I kept refusing corner blocker. Because I don't like the appearance very much.
But Although it is a tray mount, I modified it to separate it into a top case and a bottom case.
By purchasing an additional top case, you can freely choose the layout by replacing your favorite plate and PCB on the market.
(This is the merit of tray mount)
The problem is now.
I need to ask for additional prototypes.
However, the current factory has not yet delivered a perfect prototype for me. (Paid in March)
If this design is good for you, order a prototype, and if the addition of WKL or HHKB is not very important, I will open GB soon.
Please opinion of Geek
Offline EMC Labs
« Reply #59 on: Sun, 01 September 2019, 04:30:53 »
The problem is now.
Looks good. What factory will you order the prototype from?
« Last Edit: Sun, 01 September 2019, 04:36:52 by Nightcrawler »
Offline aleck
« Reply #60 on: Sun, 01 September 2019, 10:19:35 »
The problem is now.
I think the current design looks pretty good. I also think you should add WKL and HHKB options since a lot of people like those layouts, and thus, many more people will be interested in buying this case if you add them.
Offline amaddo
« Reply #61 on: Mon, 02 September 2019, 08:48:06 »
The problem is now.
KBDfans have some factory.
I kept waiting and was suggested to change the factory. I decided that there was a possibility of a great delay in mass production, so I will asked another factory for the next prototype and mass production. The distributor and shipping etc. are the same with KBDfans.
Offline MdotMaxson
« Reply #62 on: Sun, 08 September 2019, 03:59:46 »
I’m in for HHkB
Offline vitaport
« Reply #63 on: Thu, 19 September 2019, 08:42:52 »
I'd be in for a black version.  Also REALLY like the idea of just having the "無" engraved in the weight rather than the full name of the board.  I have some PCBs that would work with this case so I'll be watching for more updates
Offline amaddo
« Reply #64 on: Fri, 20 September 2019, 08:40:46 »
Do you want "Uncertainty60" Sculpture?
Minimalism people not want it.
("無" is will run reliably)
I want to geek hack user's opinion.
Offline vitaport
« Reply #65 on: Fri, 20 September 2019, 09:56:30 »
I like minimalist designs more
Offline DaneOne
« Reply #66 on: Wed, 02 October 2019, 20:31:52 »
How's it going ? any close to an ETA ?
Offline amaddo
« Reply #67 on: Sun, 13 October 2019, 02:53:16 »
Maybe Not Yet.
In order to check compatibility, you will need to make another prototype again.
As soon as it finishes, it starts GB.
Sorry for spending too much time.
Offline amaddo
« Reply #68 on: Thu, 19 December 2019, 07:20:20 »
Hi! I received Prototype photo from KBDfans!!
Before anodizing, I will report on the progress.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
Re: [IC] Uncertainty60 (Publish prototype photo)
« Reply #69 on: Fri, 20 December 2019, 18:24:48 »
This has evolved quite a bit since the IC was first published. It's looking pretty good now aesthetically.
Are you planning on the 6 standard tray mount points? Or will you do 4 or 5 post, or have removable posts like Grid 600 and newer Mekanisk boards?
Offline amaddo
« Reply #70 on: Fri, 20 December 2019, 21:59:33 »
REDESIGN Uncertainty60 PAGE
I value the opinions of GeekHack users.
It's an important element, even if you're alone.
Spec was updated and the design was modified. Thanks for your post.
Offline fluidin
Re: [IC] -無常- Uncertainty60
« Reply #71 on: Fri, 20 December 2019, 22:11:05 »
looking really good with the removable posts! just want to see more of the polycarbonate version, now
Offline amaddo
« Reply #72 on: Sat, 21 December 2019, 08:07:06 »
Yes, more render soon
Offline DJ Clicks
« Reply #73 on: Sun, 22 December 2019, 03:22:42 »
Is there an estimated price? And I'm so confused rn, which keyboard was the one that cost $175 for prototype and 15 of it was for shipping? Fellow users pls clear my confusion.
Offline Beerbezerker
« Reply #74 on: Sun, 22 December 2019, 08:25:59 »
Depending on price (once announced) I'd be in for both a polycarb + alu.
Offline amaddo
« Reply #75 on: Sun, 22 December 2019, 08:40:07 »
Add Render.
I will try to render better.
(Aluminum renders only "rose gold" to avoid color confusion.)
We will do our best for the price.
I contact KBDfans after tomorrow.
Offline DJ Clicks
« Reply #76 on: Tue, 07 January 2020, 03:46:25 »
Any updates?
Offline amaddo
« Reply #77 on: Wed, 08 January 2020, 07:22:51 »
Any updates?
Proto had some design defects.
Redesign and reproduction.
And, this production include mount points fixed.
But I cannot receive message from KBDfans long time.
Offline pegasus163
« Reply #78 on: Wed, 08 January 2020, 07:45:19 »
The design is undoubtedly impressive. The only matter is the vendor. I experienced once with KBDfans when I was ordering the hot swap PCB from them. It took me 3 weeks for a wrong tracking product, then more than 2 months for a regular hot swap PCB to be shipped to my house. Then it has turned out the package I received wasn't the pcb I wanted. In stead, it was a small square box with a piece of something that I don't even what it is. More than 3 months for unexpected stuff then I swear to God I will never come back to them ever again.
Offline amaddo
« Reply #79 on: Wed, 08 January 2020, 08:01:13 »
Yes, your bitter experience.
However, the potential for trouble is present in every transaction and will never be 0%.
I chose KBDfans as a vendor because even beginners can easily buy a keyboard and keep the price down.
Just as I chose KBDfans, you can choose not to buy with KBDfans, and I will not deny it at all.
The purchase of the product should be made at your will.
Thanks for rating Uncertainty60.
I hope you can choose freely.
Offline amaddo
« Reply #80 on: Sun, 12 January 2020, 12:05:30 »
Hi, simple update report
The prototype posted the other day had some flaws.
Therefore, at least another prototype is required. Currently redesigned from scratch, 80% of the work has been completed.
The basic appearance does not change, but the brass weight has changed.
The details will be posted at a later date.
Also, due to the redesign, the weight may be lower than originally expected.
Currently, KBDfans are busy and cannot be contacted immediately.
Since the Chinese New Year is coming soon, it is expected that it will take some time.
I'm sorry.
Offline nathanchere
« Reply #81 on: Wed, 26 February 2020, 02:27:23 »
*watching*
Offline joonia
« Reply #82 on: Wed, 26 February 2020, 07:22:20 »
need this. 100% in
Offline amaddo
« Reply #83 on: Mon, 02 March 2020, 03:59:51 »
Change weight design
Offline amaddo
« Reply #84 on: Mon, 02 March 2020, 04:03:13 »
Sorry miss.
« Last Edit: Mon, 02 March 2020, 04:04:55 by amaddo »
Offline StanleyLelnats
« Reply #85 on: Mon, 02 March 2020, 09:44:12 »
Any update on pricing with this?
Offline underheavn
« Reply #86 on: Tue, 31 March 2020, 05:08:31 »
Very interested in a polycarbonate version. Hope the production issues get sorted out soon.
Offline pchoi
« Reply #87 on: Tue, 31 March 2020, 10:35:59 »
238991-0
I would 100% be in on this if you made the chamfers on the top a little smaller (like they are in this picture) Looks too much like the Tokyo60 right now
Offline pchoi
« Reply #88 on: Tue, 31 March 2020, 10:38:26 »
^ Not saying the corners should be rounded like this, just to clarify. Only talking about the top chamfer size
Offline KFOXE
« Reply #89 on: Sun, 26 April 2020, 16:18:03 »
Any chance on a purple version being produced? Just got into the keyboard building community and was scrolling through ICs and this design caught my eye.
Also, any timeline on when we can expect the group buy to begin? Interested in purchasing one purple and one black.
« Last Edit: Thu, 30 April 2020, 01:12:23 by KFOXE »
Offline aleck
« Reply #90 on: Sun, 05 July 2020, 19:16:15 »
...is this gonna go somewhere?
Offline Vadurr
  • Valar Morghulis
« Reply #91 on: Mon, 06 July 2020, 12:35:02 »
Uncertainaf
