Author Topic: Tribosys 3203 Switch Lubricant - good for stabs?  (Read 6521 times)
Offline phinix
« on: Sun, 03 March 2019, 09:15:15 »
Hi guys. I bought Tribosys 3203 Switch Lubricant - should it be ok for stabilizers?
I have Telios 67g switches that will be soldering onto Varmilo VA69M keyboard next weekend and wanted to check if this lube be ok for stabs.
I won't be lubing Tealios, I think they are great without, but don't want those stabs be ratling, so thought I could put some lube on them?
Offline tipsyboo
Re: Tribosys 3203 Switch Lubricant - good for stabs?
« Reply #1 on: Tue, 05 March 2019, 21:37:56 »
It would be too thin. I like dielectric grease for stabs.
Offline phinix
« Reply #2 on: Wed, 06 March 2019, 07:37:31 »
OK. I also have this Super Lube Silicone Lubricating Grease with PTFE - would that be better?
Offline vegs
« Reply #3 on: Wed, 06 March 2019, 07:52:27 »
Yep! That's what I use for my stabs.
« Last Edit: Wed, 06 March 2019, 07:55:02 by vegs »
hhkb 4 life
buy less
