Author Topic: Linear Kailh BOX Switches  (Read 3069 times)
Offline Kavik
« on: Sun, 03 March 2019, 23:56:17 »
I do not own any linear Kailh BOX switches, but I'm considering BOX Blacks or BOX Dark Yellows.
To get an idea of what they might feel like, I pushed the click bar down on a BOX Navy so that it is stuck out of the way. It seems fairly smooth, but it feels a little tactile. I can't find any good pictures of a BOX Black, Red, or Dark Yellow stem to see if there is a difference where the stem contacts the green nub on the contact; that's the only part I can think of that would cause tactility without the click bar.
Is my modded BOX Navy analogous to BOX linears, or are the stems different and truly linear feeling? I just want to make sure they really are linear before buying some.
Offline vegs
Re: Linear Kailh BOX Switches
« Reply #1 on: Mon, 04 March 2019, 02:27:26 »
I haven't tried modded Navies, but Box Blacks are definitely proper linears.
hhkb 4 life
buy less
Offline _GMK_
  • not affiliated with GMK
« Reply #2 on: Mon, 04 March 2019, 02:28:27 »
kailh box switches, even the retooled ones, are known to destroy and stretch keycaps.
Offline Kavik
« Reply #3 on: Tue, 05 March 2019, 11:02:28 »
Thanks for the feedback. Do you find BOX Blacks rather smooth? I am becoming somewhat disillusioned with MX Blacks since, even with lube, only about 20% actually feel good. My one linearized BOX Navy feels pretty smooth (it just has that weird bump feeling in it).
I've thought about getting Tealios, but they are really expensive, and they don't sound great from the test videos I've seen. I was hoping BOX Blacks or Dark Yellows might fit the bill (box switches also fit in the polycarb plate more snugly, which is a plus). Though I'd probably need a stemshaver apparatus since my Dev TTY are really tight even on MX Blacks.
Offline vegs
« Reply #4 on: Wed, 06 March 2019, 01:10:26 »
Yes, Box Blacks are definitely among the smoother linears. However because of their design, they have a lot of contact points as well as a drain/opening in the bottom of the switch, so they are a bit tedious to lube. They are still great stock though.
I would however recommend you watch some Box Blacks typing videos first. They sound more similar to Tealios than MX Blacks. And yeah I'd recommend a stemshaver tool to avoid ruining your keycaps :rolleyes:
hhkb 4 life
buy less
