Author Topic: Key unresponsive but checked switch and it was fine  (Read 1563 times)
Offline Maxyol
  • “A small rock holds back a great wave”. Homer
« on: Mon, 04 March 2019, 21:27:07 »
My brother broke the fn key on my ducky mini shine (Japanese layout) what do I do
Considering selling it because don’t really want to spend more money on it
Re: Key unresponsive but checked switch and it was fine
« Reply #1 on: Mon, 04 March 2019, 21:50:03 »
How did you check it? Did you check continuity with a multimeter?
Sometimes it is not the switch but the soldering joint to the PCB that has broken — and that is often fixed by reflowing the joint by heating it with a soldering iron, and perhaps adding a little extra solder if needed.
And BTW, do also check that there isn't a DIP switch (or key-combo equivalent) that your brother could have fiddled with, which could have disabled that which you would usually use the Fn key for.
Offline Maxyol
« Reply #2 on: Mon, 04 March 2019, 22:28:23 »
No I just checked the switch wasn’t broken as he smashed really hard. But thanks I will try to re solder it
Offline Sup
« Reply #3 on: Tue, 05 March 2019, 08:56:21 »
Try to connecting the two pads with a piece of tin and if it registers the key it means the switch is defect.
current
Coming soon
