Author Topic: First build TADA68  (Read 3247 times)
Offline DoctorNunu
  • Masterworks
First build TADA68
« on: Sun, 10 March 2019, 07:33:11 »
Hey, I just acquired the parts for my first build (Tada68) and I have now got everything in place. Now I only have the hard part left (according to me) which is flashing and keymapping etc.
First of all, I have been watching som guides on how to use the QMK toolbox, and I have now downloaded a finished bin file to flash my keyboard with. The first problem I ran into is that it's a bin file and not a hex file, I read that this is the standard for Tada68, but I want to make sure I am doing the right thing.
The second problem is that I can't find anywhere which type of microcontroller the Tada uses, does anyone have info on this?
As soon as I got these problems sorted out I will be flashing my keyboard accordning to some general youtube videos, if anyone has any advice and do's and dont's, please let me know :)
I am very excited to get into the mechanical keyboards lifestyle, and I am hoping that this interest is something that will keep me going!
Offline AJM
Re: First build TADA68
« Reply #1 on: Sun, 10 March 2019, 13:42:20 »
Forget GMQ toolbox and all the microcontroller driver nuisance.
If you have a bin file, it's very easy.
- rename it to "FLASH.BIN"
- press the reset button under the keyboard
- a new drive pops up in Windows explorer
- delete the old file "FLASH.BIN" an that drive (keyboard)
- copy your "FLASH.BIN" onto it
- press ESC
(If you have a Mac it could be bit tricky - says "the internet")
Offline DoctorNunu
  • Masterworks
« Reply #2 on: Wed, 13 March 2019, 09:05:46 »
- press ESC
Thanks, that was alot easier than I anticipated. Do you have any tips for other PCB's that doesn't require a hex file and/or QMK to flash?
I am getting a 60% board and a 75% board.
Offline AJM
« Reply #3 on: Wed, 13 March 2019, 09:53:14 »
You're welcome.
(I have "filled up" two PCs with dozens of drivers, trying to get the QMK toolbox to work, before I found this way.)
The Tada68 is my only fully programmable keyboard (apart from a few Vortex boards) so far, so I have no experience with other flashing procedures, I'm afraid.
