Author Topic: Odd problem with IBM Model F  (Read 1242 times)
Offline phughes
« on: Mon, 11 March 2019, 08:45:41 »
Hi all,
I hope someone may be able to point me in the right direction with a strange issue I'm experiencing while refurbishing my IBM Model F.
I have stripped it down completely, cleaned everything, fitted new foam and re-assembled.  I am using a Teensy board running Soarer's Converter and it all works apart from the following annoying problem:
All keys work except "c" and "m".
If I gently slacken the grounding screw on the PCB (location indicated in photo), the "c" and "m" keys work - but none of the other keys! I can't get the screw at the "sweet spot" where all keys work   :mad:
I took the damn thing apart several times thinking that this was a problem with the contacts underneath!
I know that Model F is quite sensitive, but this problem is driving me crazy.
Any ideas much appreciated!
Regards,
Paul
