Author Topic: IBM model M right shift key problem  (Read 1642 times)
Offline ccfd
« on: Sat, 16 March 2019, 09:48:28 »
I recently bought a model M 1391401, and I bolt modded it.
Well....
My 'x' key does not work with right shift key.
The left shift key works fine so that I can print uppercase x "X".
But I can't do this with my right shift key
The right shift key works fine with other keys.
Anyone knows why this is happening and what is the solution to this?
« Last Edit: Sat, 16 March 2019, 09:51:45 by ccfd »
Offline mapple
Re: IBM model M right shift key problem
« Reply #1 on: Mon, 18 March 2019, 14:33:38 »
only way which I could imagine is either replace controller or if you can't try to contact unicomp they might be able to help you out.
In God We Trust
